BT.com
Wishlist
ViewSonic VX2210mh-LED 22" LED Full HD 1080p DVI-D & HDMI 5ms Speakers
Delivery
Standard Due date unavailable
ViewSonic's 22" VX2210mh-LED display features eco-friendly LED backlighting and power-saving modes for a green viewing experience. It's equipped with our exclusive ClearMotiv® II video technology that enables vivid, smooth images without distortion or blur. The display automatically adjusts brightness levels and maximizes the greyscale and colour range to achieve an extreme 20,000,000:1 dynamic contrast ratio! Its Full HD 1080p video resolution and 16:9 aspect ratio deliver an exciting, widescreen viewing experience. And with a slim profile, the VX2210mh-LED saves space on your desk. ClearMotiv® II 5ms video response Innovative ClearMotiv® II imaging technology enables an ultrafast 5ms liquid crystal response time. Experience digital broadcast-quality, full-motion video with sharp images that never blur.
Energy savings with ECO Mode
ECO Mode reduces power consumption up to 40%. Select the Optimize (75%) or Conserve (60%) options to reduce display brightness, save money and help the environment. Adjusting the brightness will improve visibility and reduce eye fatigue, especially under low ambient light conditions.
Full HD 1080p resolution
1920 x 1080 Full HD video resolution enables premium viewing quality through a 16:9 screen. Enjoy spectacular widescreen presentations with vivid, clear images in your home or office.
LED backlight
LED backlights enhance display performance by delivering an outstanding colour gamut and contrast ratio to create remarkably refined images. LEDs also provide energy savings and slimmer displays for a new entertainment experience.
Superb 20,000,000:1 dynamic contrast ratio
Dynamic contrast ratio automatically detects the brightness of an image and adjusts the LED backlight in response. It maximizes the greyscale and colour range and boosts contrast ratio to an ultrahigh 20,000,000:1, resulting in rich, vibrant visuals.
ViewSonic VX2210MH-LED - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
51.1 cm x 16.4 cm x 37.1 cm
3.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
CB, CCC, RoHS, WEEE, GOST-R, REACH, UkrSEPRO, ERP, CEL
(Austria, Germany, Switzerland - 2 years)
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Eco-Mode, ClearMotiv II
51.1 cm x 16.4 cm x 37.1 cm - with stand
3.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , Audio line-in , Audio line-out , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
Stand
Backlight Life
40,000 hours
Power Supply
Internal
19 Watt
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 16.4 cm - height: 37.1 cm - weight: 3.5 kg , Without stand - width: 51.1 cm - depth: 6.2 cm - height: 31 cm - weight: 3.2 kg
ENERGY STAR Certified
5 - 90% (non-condensing)
Scroll to top
