BT.com
Wishlist
ViewSonic VP2780-4K 27" 3840x2160 4K UHD HDMI MHL DisplayPort IPS LED Monitor
ViewSonic VP2780-4K 27" 3840x2160...
£725.65
£725.65
Add to wishlist
Delivery
Standard Due date unavailable
The ViewSonic VP2780-4K 27" Professional Ultra HD LED monitor delivers stunning definition for color-critical applications. With its high resolution, and SuperClear IPS technology for wide-angle viewing, this 10-bit monitor can display up to 1.07 billion colors. It provides superior color accuracy and performance for content creation, graphic design, print, and other professional applications. Equipped with an exclusive wide-range gamma setting and ViewMode technology, the VP2780-4K delivers optimized screen adjustments for different viewing scenarios. One of the first Ultra HD monitors to feature future-proof HDMI 2.0 to support 3840x2160 content at 60hz, along with DisplayPort 1.2a, dual MHL connectivity, and 4-port USB 3.0 for versatile connectivity to computing and entertainment devices. ViewSonic's MultiPicture functionality allows for efficient multitasking by providing simultaneous viewing of up to four split windows, while full ergonomic functionality delivers maximum comfort and enhanced productivity.
ViewSonic VP2780-4K - LED monitor - 27"
LED-backlit LCD monitor - 27"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, 2xMHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
64.27 cm x 34.78 cm x 46.97 cm
8.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, CB, RoHS, WEEE, TCO '06, REACH, ISO 9001:2008, ISO 14001:2004, TUV Nord, ERP, TCO Displays 6.0, CoC
Display Type
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen
Native Resolution
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
24 - 120 Hz
Horizontal Refresh Rate
15 - 204 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour balance, gamma correction, input select
Sync on Green, SuperClear, Eco-Mode, Colour gamut EBU, Advanced Frame Rate Control (AFRC), MultiPicture
64.27 cm x 34.78 cm x 46.97 cm - with stand
8.4 kg
HDMI , 2 x MHL / HDMI , DisplayPort , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream (Type B) , Headphones
Mechanical
Tilt Angle
-5/+23
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DisplayPort cable , 1 x Mobile High-Definition Link (MHL) cable , 1 x HDMI cable , 1 x USB cable
Backlight Life
30,000 hours
Power Supply
External
AC 120/230 V (50 - 60 Hz)
49 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 64.27 cm - depth: 5.6 cm - height: 38.17 cm - weight: 5.4 kg , With stand - width: 64.27 cm - depth: 34.78 cm - height: 46.97 cm - weight: 8.4 kg
20 - 90% (non-condensing)
Scroll to top
