BT.com
Wishlist
ViewSonic VP2772 27" 2560x1440 6ms DVI-D HDMI DisplayPort LED Monitor
ViewSonic VP2772 27" 2560x1440 6ms...
£728.44
£728.44
Add to wishlist
Delivery
Standard 1-3 working days
ViewSonic's VP2772 is a 27" ultra-high resolution display with 2560 x 1440 QHD resolution and 10-bit color. Covering 99% of the Adobe RGB color space, the VP2772 meets the high color standards of photographers, graphic designers, video editors, print departments, and other design professionals. With its advanced 12-bit color engine and 14-bit LUT, the VP2772 smoothly processes, grades, and renders 68.7 billion colors to create stunning images with rich depth and detail. Equipped with dual DisplayPort inputs and one DisplayPort output, it allows one image source to be shown simultaneously on multiple daisy-chained displays without any difference in color. In addition, HDMI and DVI inputs, and four USB 3.0 ports let users connect with multimedia and storage devices. The VP2772 is also ergonomically designed with tilt, pivot, swivel and height adjustments to create a more comfortable and efficient working environment. The ViewSonic VP2772 is the ultimate professional grade display for the most demanding color-critical applications.
ViewSonic VP2772 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
85.1 kWh
Power Consumption (On mode)
58.3 W
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
QHD 2560 x 1440
Brightness
350 cd/m2
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
6 ms
Input Connectors
HDMI, DVI-D, 2xDisplayPort
Display Position Adjustments
Height adjustable, pivot (rotation), swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
64.26 cm x 34.8 cm x 46.48 cm - with stand
8.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, NOM, TUV S, CB, CCC, PSB, RoHS, WEEE, GOST-R, REACH, UkrSEPRO, ERP, CECP, CEL, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class C
85.1 kWh
58.3 W
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
QHD 2560 x 1440
Brightness
350 cd/m2
Contrast Ratio
Response Time
6 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 92 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
HDCP, SuperClear, Eco-Mode, 14-bit gamma, 99% Adobe RGB colour gamut
8.5 kg
HDMI ( HDCP ) , DVI-D (dual link) ( HDCP ) , DisplayPort , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in , Headphones , DisplayPort output
Mechanical
Tilt Angle
-5/+23
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DisplayPort cable , 1 x HDMI cable , 1 x DVI cable , 1 x SuperSpeed USB cable
Backlight Life
30,000 hours
Power Supply
External
AC 120/230 V ( 50 - 60 Hz )
65 Watt
On / Off Switch
No
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 64.26 cm - depth: 5.6 cm - height: 38.1 cm - weight: 5.5 kg , With stand - width: 64.26 cm - depth: 34.8 cm - height: 46.48 cm - weight: 8.5 kg
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
20 - 90% (non-condensing)
Scroll to top
