BT.com
Wishlist
ViewSonic VG2860mhl-4k 28" 2ms DVI DP HDMI 4K Monitor
Delivery
Standard Due date unavailable
If you're writing thousands of lines of code, making financial forecasts, or viewing video surveillance footage, the efficiency of your work often comes down to the details on your monitor. With stunning 3840x2160 resolution at a high refresh rate of 60Hz, this 28" monitor is engineered to deliver the ultimate in detail and clarity so that the finer points never go by unnoticed. When multiple projects need your attention, ViewSonic's exclusive MultiPicture functionality lets you view up to four Full HD video sources at once, while a fully adjustable ergonomic stand keeps you comfortable. The ViewSonic VG2860mhl-4K monitor delivers the screen size, incredible detail, and multitasking features you need to get your job done.
ViewSonic VG2860mhl-4K - LED monitor - 28"
LED-backlit LCD monitor - 28"
Stereo speakers, USB 3.0 hub
Aspect Ratio
Widescreen - 16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz, DVI: 30 Hz)
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
2 ms (gray-to-gray)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort, MHL
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
65.97 cm x 26.6 cm x 48.34 cm
7.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, WHQL, CB, RoHS, WEEE, cULus, REACH, ERP
3 years warranty
Display Type
Diagonal Size
28"
Viewable Size
28"
Built-in Devices
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
24 - 160 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
Eco-Mode, a-Si technology, Blue Light Filter technology
65.97 cm x 26.6 cm x 48.34 cm - with stand
7.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
HDMI , MHL / HDMI , 2 x DisplayPort , DVI-D , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream , USB 3.0 upstream (Type B) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+37
Swivel Angle
350
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Flicker-free technology
Stand
1 x DisplayPort cable , 1 x Mobile High-Definition Link (MHL) cable , 1 x audio cable , 1 x USB cable
Backlight Life
30,000 hours
48 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 65.97 cm - depth: 26.6 cm - height: 48.34 cm - weight: 7.8 kg , Without stand - width: 65.97 cm - depth: 4.93 cm - height: 39.1 cm - weight: 5.3 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 90% (non-condensing)
Scroll to top
