BT.com
Wishlist
ViewSonic VG2437SMC 23.6" VGA DVI DP USB LED Monitor with Integrated Webcam
ViewSonic VG2437SMC 23.6" VGA DVI...
£209.83
More than 50 in stock
£209.83
Add to wishlist
Delivery
Standard 1-3 working days
The ViewSonic VG2437Smc is a 24" (23.6" viewable) Full HD ergonomic monitor with an integrated 2-megapixel webcam, dual speakers, and mic/headphone ports for video conferencing. With 1920x1080 resolution, SuperClear MVA technology for wide-angle viewing, and 20M: 1 dynamic contrast ratio, this monitor provides incredibly sharp pictures and stunning video playback.
An integrated future-proof DisplayPort input, as well as DVI, VGA, and 2-port USB hub, offer easy and flexible connectivity options for viewing digital content sources, transferring files, and attaching peripherals. The LED backlight design makes this monitor Energy Star and EPEAT Silver certified. Standard 100 x 100mm VESA mount allows flexible wall mounting or display arm installation.
ViewSonic VG2437SMC - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Camera, 2.0 megapixel camera, USB 2.0 hub
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
6.9 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
55.68 cm x 23.96 cm x 45.09 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, cUL, RoHS, WEEE
3 years warranty
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Built-in Devices
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast
SuperClearMVA, Eco-Mode, Flicker Free technology, Mercury free, Blue Light Filter technology
55.68 cm x 23.96 cm x 45.09 cm - with stand
5.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Input
Camera
VGA , DVI-D , DisplayPort , 2 x USB 2.0 upstream , Audio line-in , Microphone , Headphones , Audio line-out
Mechanical
Tilt Angle
-3/+25
Swivel Angle
360
Rotation Angle
90
Height Adjustment
135 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable , 1 x microphone cable
Power Supply
Internal
24.5 Watt
Included Software
ViewSonic Wizard
Microsoft Windows Vista / 7 / 8
Dimensions & Weight Details
With stand - width: 55.68 cm - depth: 23.96 cm - height: 45.09 cm - weight: 5.2 kg , Without stand - width: 55.68 cm - depth: 6.05 cm - height: 34.03 cm - weight: 3.7 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
20 - 90% (non-condensing)
Scroll to top
