BT.com
Wishlist
ViewSonic VG2435SM 24" 1920x1200 5ms DVI IPS Monitor
Delivery
Standard Due date unavailable
ViewSonic's VG2435Sm high-performance multimedia display features 1920 x 1200 resolution with 16:10 aspect ratio that provides a larger screen surface for increased office place productivity. With SuperClear wide-angle viewing technology, 50M: 1 dynamic contrast ratio and dual stereo speakers, it delivers sharp, consistent and true color performance together with crystal-clear sound effects. Fully ergonomic with flexible adjustment options, creating a more comfortable working environment is easy. In addition, it comes equipped with Flicker-free and Blue Light Filter technologies that reduce eye discomfort for daily users.
ViewSonic VG2435Sm - LED monitor - 24"
LED-backlit LCD monitor - 24"
Aspect Ratio
Widescreen - 16:10
Native Resolution
1920 x 1200
Brightness
250 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
55.68 cm x 20.43 cm x 39.36 cm
5.7 kg
Environmental Standards
ENERGY STAR Qualified
GS, TUV Ergo, REACH, UkrSEPRO, ERP
Display Type
Diagonal Size
24"
Aspect Ratio
Widescreen - 16:10
Native Resolution
1920 x 1200
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, colour balance, input select, H-size, aspect control, blue reduction
sRGB colour management, SuperClear, Eco-Mode, Flicker Free technology, blue light reduction, Mercury free, a-Si technology
55.68 cm x 20.43 cm x 39.36 cm - with stand
5.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+37
Swivel Angle
360
Rotation Angle
90
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Backlight Life
30,000 hours
Power Supply
Internal
31 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 55.68 cm - depth: 5.15 cm - height: 36.3 cm - weight: 4.1 kg , With stand - width: 55.68 cm - depth: 20.43 cm - height: 39.36 cm - weight: 5.7 kg
10 - 90% (non-condensing)
Scroll to top
