BT.com
Wishlist
ViewSonic VG2433-LED 24" 1920x1080 5ms VGA DVI-D LED Monitor
ViewSonic VG2433-LED 24" 1920x1080...
£156.67
23 in stock
£156.67
Add to wishlist
Delivery
Standard 1-3 working days
The ViewSonic VG2433-LED is a 23.6" display ideal for demanding business professionals. With a native 1920 x 1080 resolution, the VG2433-LED delivers vibrant images and crisp text. Users will also find comfort in the fully ergonomic height adjust, swivel, and tilt features. Equipped with a VESA-mountable design, the display can be mounted on a wall or any VESA-compliant monitor stand. The VG2433-LED also saves up to 50% in energy usage with its efficient LED backlight.
ViewSonic VG2433-LED - LED monitor - 23.6"
LED-backlit LCD monitor - 23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
FullHD 1920 x 1080
Brightness
300 cd/m2
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height adjustable, pivot (rotation), swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
56.6 cm x 20.43 cm x 38.24 cm - with stand
4.66 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified , EPEAT Silver
3 years warranty
Display Type
Diagonal Size
23.6"
Viewable Size
23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
FullHD 1920 x 1080
Brightness
300 cd/m2
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
sRGB colour management, Eco-Mode, Mega Dynamic Contrast Ratio
4.66 kg
VGA , DVI-D
Mechanical
Tilt Angle
-5/+25
Swivel Angle
360
Rotation Angle
90
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Backlight Life
30,000 hours
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
22 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 56.6 cm - depth: 20.43 cm - height: 38.24 cm - weight: 4.66 kg , Without stand - width: 56.6 cm - depth: 5.1 cm - height: 34.32 cm - weight: 3.22 kg
EPEAT Compliant
EPEAT Silver
3 years warranty
Service & Support Details
Limited warranty - 3 years
10 - 90% (non-condensing)
Scroll to top
