BT.com
Wishlist
ViewSonic VG2239SMH 22" 1920x1080 5ms VGA HDMI DP USB LED Monitor
ViewSonic VG2239SMH 22" 1920x1080...
£145.47
More than 50 in stock
£145.47
Add to wishlist
Delivery
Standard 1-3 working days
The ViewSonic VG2239Smh is a Full HD LED multimedia monitor with future-proof connectivity and full ergonomic functionality ideal for corporate, government and education.
With SuperClear MVA panel technology for wide-angle viewing, and 20M: 1 dynamic contrast ratio, this monitor delivers incredibly sharp images and video playback. Integrated with HDMI, DisplayPort, VGA and 2 USB ports, the VG2239Smh allows flexible connection to PC systems, laptops and other multimedia peripheral devices.
ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, Flicker-Free and Blue Light Filter technology help to eliminate eye strain from extended viewing periods. The LED backlight design makes this display ENERGY STAR and EPEAT gold certified.
ViewSonic VG2239Smh - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
MVA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
6.5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
51.24 cm x 23.96 cm x 41.8 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, cUL, WHQL, CB, RoHS, WEEE
3 years warranty
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
MVA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, input select
SuperClear, Eco-Mode, Blue Light Filter technology
51.24 cm x 23.96 cm x 41.8 cm - with stand
4.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , Audio line-in , Headphones , 2 x USB 2.0 , USB 2.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
360
Rotation Angle
90
Height Adjustment
135 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Flicker-free technology
Stand
1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
Backlight Life
30,000 hours
Power Supply
Internal
20.5 Watt
Included Software
Driver, ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 51.24 cm - depth: 23.96 cm - height: 41.8 cm - weight: 4.8 kg , Without stand - width: 51.24 cm - depth: 5.64 cm - height: 30.44 cm - weight: 3.3 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years ¦ Limited warranty - backlight - 3 years
10 - 90% (non-condensing)
Scroll to top
