BT.com
Wishlist
ViewSonic VG2235M 22" 1680x1050 5ms DVI LCD Monitor
ViewSonic VG2235M 22" 1680x1050 5ms...
£130.42
£130.42
Add to wishlist
Delivery
Standard Due date unavailable
ViewSonic's VG2235m is a fully ergonomic 22'' multimedia display that features 1680 x 1050 resolution, 16:10 aspect ratio, and flexible adjustment options to provide a larger on-screen work area for greater productivity and comfort. Daily users will appreciate ViewSonic's Flicker-free and Blue Light Filter eye-care technologies that reduce eye fatigue caused by prolonged use. This ViewSonic LED display's the perfect choice for corporate, government, SMB and educational institutions.
ViewSonic VG2235m - LED monitor - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
Widescreen
Native Resolution
1680 x 1050
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
51.24 cm x 20.43 cm x 38.9 cm
4.85 kg
GS, TUV Ergo, DOC, REACH, UkrSEPRO, ERP
3 years warranty
Display Type
Diagonal Size
22"
Aspect Ratio
Widescreen
Native Resolution
1680 x 1050
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
sRGB colour management, Eco-Mode, Flicker Free technology, blue light reduction, Mercury free, a-Si technology
51.24 cm x 20.43 cm x 38.9 cm - with stand
4.85 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , Audio line-in
Mechanical
Tilt Angle
-5/+37
Swivel Angle
360
Rotation Angle
90
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x audio cable
Backlight Life
30,000 hours
Power Supply
Internal
18.5 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 51.24 cm - depth: 4.77 cm - height: 33.53 cm - weight: 3.25 kg , With stand - width: 51.24 cm - depth: 20.43 cm - height: 38.9 cm - weight: 4.85 kg
Limited warranty - 3 years
10 - 90% (non-condensing)
Scroll to top
