BT.com
Wishlist
ViewSonic VG2039M-LED 20" 1600x900 5ms VGA DVI DisplayPort USB LED Monitor
ViewSonic VG2039M-LED 20" 1600x900...
£120.26
19 in stock
£120.26
Add to wishlist
Delivery
Standard 1-3 working days
The ViewSonic VG2039m-LED is a 20" (19.5" viewable) widescreen display ideal for demanding business professionals. With a native 1600 x 900 resolution, the VG2039m-LED delivers vibrant images and crisp text. Users will also find comfort in the fully ergonomic height adjust, swivel, and tilt features. Versatile input options, including DisplayPort, DVI-D, and VGA, provide flexible connectivity for multitasking. Equipped with a VESA-mountable design, the display can be mounted on a wall or any VESA-compliant monitor stand. The thin bezel design, coupled with hidden stereo speakers, makes the VG2039m-LED a space-saving option for the desktop. In addition to saving space, the VG2039m-LED also saves up to 50% in energy usage with its efficient LED backlight.
ViewSonic VG2039M-LED - LED monitor - 20"
LED-backlit LCD monitor - 20"
Energy Class
Class A+
Energy Consumption per Year
21 kWh
Power Consumption (On mode)
14 W
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900 at 60 Hz
Brightness
250 cd/m2
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Height adjustable, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
46.6 cm x 25 cm x 38.2 cm - with stand
3.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, cUL, RoHS, REACH, TUV Nord
3 years warranty
Display Type
Energy Class
Class A+
21 kWh
14 W
Diagonal Size
20"
Viewable Size
19.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900 at 60 Hz
Brightness
250 cd/m2
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour balance, input select
Eco-Mode
3.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D ( HDCP ) , DisplayPort , 2 x USB 2.0 downstream , USB 2.0 upstream , Audio line-in , Headphones
Mechanical
Height, swivel, tilt
Tilt Angle
-5/+20
Swivel Angle
360
Height Adjustment
80 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x audio cable , 1 x USB cable , 1 x DVI cable , 1 x VGA cable
Backlight Life
30,000 hours
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
17 Watt
On / Off Switch
No
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 46.6 cm - depth: 25 cm - height: 38.2 cm - weight: 3.7 kg , Without stand - width: 46.6 cm - depth: 5.9 cm - height: 27.4 cm - weight: 2.6 kg
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 90% (non-condensing)
Scroll to top
