BT.com
Wishlist
ViewSonic VA2465SM-3 23.6" 1920x1080 5ms VGA DVI with Speakers
ViewSonic VA2465SM-3 23.6"...
£124.48
£124.48
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The ViewSonic VA2465SM-3 is a widescreen monitor with an LED backlight and glossy, thin-bezel design great for use in the home or at the office. With Full HD resolution, high static contrast ratio and SuperClear VA technology, the VA2465SM-3 delivers stunning color and contrast with amazing screen performance at any viewing angle. Flicker Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. Paired with VGA and DVI inputs, the VA2465SM-3 allows flexible connection to PC systems, laptops and other multimedia devices. As a complete multimedia package, the monitor also includes a pair of integrated speakers.
ViewSonic VA2465Sm-3 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
56.389 cm x 19.314 cm x 40.719 cm
4.1 kg
Europe
Environmental Standards
ENERGY STAR Qualified
CB, FCC, RoHS, WEEE, REACH, UkrSEPRO, ERP, TCO Displays 6.0
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
SuperClear, Eco-Mode, Flicker Free technology, Blue Light Filter technology, 94.4% sRGB colour gamut, 73% Adobe RGB colour gamut, 67% NTSC colour gamut
56.389 cm x 19.314 cm x 40.719 cm - with stand
4.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI , Audio line-out , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Europe
AC 100/240 V (50/60 Hz)
22 Watt
Dimensions & Weight Details
Without stand - width: 56.389 cm - depth: 4.596 cm - height: 34.709 cm - weight: 3.6 kg , With stand - width: 56.389 cm - depth: 19.314 cm - height: 40.719 cm - weight: 4.1 kg
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Damaged stock - Item is new but has packaging damage
Ref: BP7R 035490
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£108.46
Ref: BP7R 035491
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£108.46
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
