BT.com
Wishlist
ViewSonic VA2465S-3 24" 1920x1080 5ms VGA DVI-D LCD Monitor
Delivery
Standard Due date unavailable
The ViewSonic VA2465S-3 is a 24" widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920 x 1080 resolution, 3000:1 static contrast ratio and SuperClear VA technology, the VA2465S-3 delivers stunning color and contrast with amazing screen performance at any viewing angle. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, flicker-free technology and a blue light filter help to eliminate eye strain from extended viewing periods. Paired with VGA and DVI inputs, the VA2465S-3 allows flexible connection to PC systems, laptops and other multimedia devices. A VESA-mountable design offers additional mount flexibility. In addition, ViewSonic offers one of the industry's best pixel performance policies to provide a great value for the stylish, high-performance VA2465S-3 monitor.
ViewSonic VA2465S-3 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
56.389 cm x 19.314 cm x 40.719 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
CB, FCC, RoHS, WEEE, REACH, UkrSEPRO, ERP, TCO Displays 6.0
(Austria, Germany, Switzerland - 2 years)
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
SuperClear, Eco-Mode, Flicker Free technology, Mercury free, Blue Light Filter technology
56.389 cm x 19.314 cm x 40.719 cm - with stand
4.1 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
22 Watt
Dimensions & Weight Details
Without stand - width: 56.389 cm - depth: 4.596 cm - height: 34.709 cm - weight: 3.6 kg , With stand - width: 56.389 cm - depth: 19.314 cm - height: 40.719 cm - weight: 4.1 kg
ENERGY STAR Certified
Scroll to top
