BT.com
Wishlist
ViewSonic VA2445-LED 24" 1920x1080 5ms VGA DVI-D LED Black Monitor
ViewSonic VA2445-LED 24" 1920x1080...
£97.42
More than 50 in stock
£97.42
Add to wishlist
Delivery
Standard 1-3 working days
The ViewSonic VA2446-LED is a 24" (23.6 Vis) widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920 x 1080 resolution and a 10M:1 dynamic contrast ratio, the VA2446-LED delivers stunning brightness and contrast, while a quick 5ms response time ensures crisp pictures and smooth playback. VGA and DVI inputs provide flexible and convenient connectivity, while a VESA-mountable design offers additional mount flexibility. With an efficient LED backlight and energy-saving Eco mode, the VA2446-LED is an environmentally friendly display choice.
ViewSonic VA2445-LED - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Aspect Ratio
Widescreen
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
57.14 cm x 21.21 cm x 40.09 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, C-Tick, BSMI, cUL, CB, ICES-003 Class B, CCC, PSB, RoHS, WEEE, REACH, UkrSEPRO, ERP
2 years warranty (Austria, Germany, Switzerland - 2 years)
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Aspect Ratio
Widescreen
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Eco-Mode, Mega Dynamic Contrast Ratio
57.14 cm x 21.21 cm x 40.09 cm - with stand
4.1 kg
DVI-D , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Backlight Life
30,000 hours
Power Supply
Internal
22 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 57.14 cm - depth: 21.12 cm - height: 40.09 cm - weight: 4.1 kg , Without stand - width: 57.14 cm - depth: 5.04 cm - height: 35.09 cm - weight: 3.72 kg
ENERGY STAR Certified
10 - 90% (non-condensing)
Scroll to top
