BT.com
Wishlist
ViewSonic VA2265SMH 22" SuperClear MVA LED Monitor 1920x1080
Clearance
Last Few Remaining
Price Drop
Price Drop!
Delivery
Standard Due date unavailable
The ViewSonic VA2265Smh is a 22" (21.5" viewable) widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920x1080 resolution, 3000:1 static contrast ratio, and SuperClear VA technology, the VA2265Smh delivers stunning brightness and contrast with amazing screen performance at nearly any viewing angle. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, Flicker-Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. Paired with versatile input options including HDMI and VGA, the VA2265Smh allows flexible connection to PC systems, laptops and other multimedia devices. As a complete multimedia package, the monitor also includes a pair of integrated speakers. A VESA-mountable design offers additional mount flexibility.
ViewSonic VA2265Smh - LED monitor - 22"
LED-backlit LCD monitor - 22"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
6.5 ms (grey-to-grey)
Input Connectors
HDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
56.389 cm x 19.314 cm x 40.719 cm
4.1 kg
3 years warranty
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
SuperClear, Eco-Mode, Flicker Free technology, Mercury free, Blue Light Filter technology
56.389 cm x 19.314 cm x 40.719 cm - with stand
4.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Power Supply
Internal
22 Watt
Dimensions & Weight Details
Without stand - width: 56.389 cm - depth: 4.596 cm - height: 34.709 cm - weight: 3.6 kg , With stand - width: 56.389 cm - depth: 19.314 cm - height: 40.719 cm - weight: 4.1 kg
Limited warranty - 3 years
10 - 90% (non-condensing)
Scroll to top
