BT.com
Wishlist
ViewSonic VA2265SM 22" 1920x1080 5ms VGA DVI LED Monitor
ViewSonic VA2265SM 22" 1920x1080...
£110.50
Hurry, only 3 left in stock!
£110.50
Add to wishlist
Delivery
Standard 1-3 working days
The ViewSonic VA2265Sm-3 is a widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920x1080 resolution, 3000:1 static contrast ratio and SuperClear VA technology, the VA2265Sm-3 delivers stunning color and contrast with amazing screen performance at nearly any viewing angle. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, Flicker-Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. Paired with VGA and DVI inputs, the VA2265Sm-3 allows flexible connection to PC systems, laptops and other multimedia devices. As a complete multimedia package, the monitor also includes a pair of integrated speakers. A VESA-mountable design offers additional mount flexibility. In addition, ViewSonic offers one of the industry's best pixel performance policies to provide a great value for the stylish, high-performance VA2265SM-3 monitor.
ViewSonic VA2265Sm-3 - LED monitor - 22"
LED-backlit LCD monitor - 22"
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
51.069 cm x 19.314 cm x 38.761 cm
3.6 kg
Europe
Environmental Standards
ENERGY STAR Qualified
CB, FCC, RoHS, WEEE, REACH, UkrSEPRO, ERP, TCO Displays 6.0
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
SuperClear, Eco-Mode, Flicker Free technology, 96% sRGB colour gamut, Blue Light Filter technology, 74% Adobe RGB colour gamut, 71% NTSC colour gamut
51.069 cm x 19.314 cm x 38.761 cm - with stand
3.6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI , Audio line-out , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Europe
AC 100/240 V (50/60 Hz)
22 Watt
Dimensions & Weight Details
Without stand - width: 51.069 cm - depth: 4.716 cm - height: 31.938 cm - weight: 3 kg , With stand - width: 51.069 cm - depth: 19.314 cm - height: 38.761 cm - weight: 3.6 kg
Scroll to top
