BT.com
Wishlist
ViewSonic VA2265SH 22" 1920x1080 5ms VGA HDMI LED Monitor
ViewSonic VA2265SH 22" 1920x1080...
£110.32
More than 50 in stock
£110.32
Add to wishlist
Delivery
Standard 1-3 working days
The ViewSonic VA2265Sh is a widescreen monitor with an LED backlight and glossy, thin-bezel design ideal for use in the home or at the office. With Full HD 1920 x 1080 resolution, 3000:1 static contrast ratio, and SuperClear VA technology, the VA2265Sh delivers stunning brightness and contrast with amazing screen performance at nearly any viewing angle. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, flicker-free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. Paired with versatile input options including HDMI and VGA, the VA2265Sh allows flexible connection to PC systems, laptops and other multimedia devices. A VESA-mountable design offers additional mount flexibility.
ViewSonic VA2265Sh - LED monitor - 22"
LED-backlit LCD monitor - 22"
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
51.069 cm x 19.314 cm x 38.761 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
C-Tick, BSMI, CB, PSB, FCC, RoHS, WEEE, Green Mark, MEPS, REACH, ERP, TCO Displays 6.0, NMB-3 Class B, CAN ICES-3 Class B
2 years warranty
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
SuperClear, Eco-Mode, Flicker Free technology, 96% sRGB colour gamut, Mercury free, Blue Light Filter technology, 74% Adobe RGB colour gamut, 71% NTSC colour gamut
51.069 cm x 19.314 cm x 38.761 cm - with stand
3.6 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Backlight Life
40,000 hours
22 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 51.069 cm - depth: 4.716 cm - height: 31.938 cm - weight: 3 kg , With stand - width: 51.069 cm - depth: 19.314 cm - height: 38.761 cm - weight: 3.6 kg
10 - 90% (non-condensing)
Scroll to top
