BT.com
Wishlist
ViewSonic VA2055SA 19.5" Full HD VGA Monitor
Delivery
Standard Due date unavailable
The ViewSonic VA2055Sa features a 20" Full HD SuperClear MVA widescreen panel. The monitor offers 1920 x 1080 resolution, 3,000:1 contrast ratio, VGA inputs, and a VESA-compatible mount design. In addition, Flicker-Free and blue light filter technology help to eliminate eye strain from extended viewing periods. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. Lastly, with one of the industry's best pixel performance policies, ENERGY STAR and EPEAT Silver certification, and an energy-saving Eco-mode, the VA2055Sa is a great long-term investment for any of your entertainment or professional needs.
ViewSonic VA2055Sa - LED monitor - 20"
LED-backlit LCD monitor - 20"
Panel Type
MVA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
25 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
47.22 cm x 21.17 cm x 34.91 cm
3.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, ICES-003, cULus, cTUVus, NRTL, cETLus
3 years warranty
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Panel Type
MVA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select
SuperClear, Eco-Mode, Flicker Free technology, Blue Light Filter technology
47.22 cm x 21.17 cm x 34.91 cm - with stand
3.1 kg
VGA
Mechanical
Tilt
Tilt Angle
-3/+20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Backlight Life
30,000 hours
Power Supply
External
24 Watt
Dimensions & Weight Details
With stand - width: 47.22 cm - depth: 21.17 cm - height: 34.91 cm - weight: 3.1 kg , Without stand - width: 47.22 cm - depth: 4.75 cm - height: 28.78 cm - weight: 2.5 kg
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
20 - 90% (non-condensing)
Scroll to top
