Click to visit BT.com
BT.com
Wishlist
ViewSonic VA1912-LED 18.5" 1366x768 VGA DVI 5MS LED Monitor
Quicklinx: 8K6JWS00
Mfr#: VA1912-LED
Essential accessories
The VA1912-LED monitor is ideal for easy daily works such as writing, web surfing, learning, gaming or video viewing. This monitor boasts a great performance and affordable price without compromising on ease of use, image quality and environmental friendliness. The VA1912-LED has many features such as a premium 16:9 display of 10,000,000:1 dynamic contrast ratio; the capability to dynamically adjust the backlit module according to the input signal; a 1366 x 768 resolution with HD compatibility; brilliant colors, darker black with no distortion and VGA and DVI inputs. This monitor offers a full array of functions via its OSD interface, including the TCO and ENERGY STAR compliant eco-mode that can reduce power consumption by up to 70% and therefore extends backlight life significantly. This ultra-slim bezel, glossy finish and small desktop footprint of the VA1912-LED make it a nice addition to your desk and lifestyle. This monitor will satisfy your viewing requirements at an affordable price.
ViewSonic VA1912-LED - LED monitor - 19"
LED-backlit LCD monitor - 19"
Aspect Ratio
Widescreen - 16:9
Native Resolution
HD 1366 x 768
Pixel Pitch
0.3 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
44.43 cm x 18 cm x 35.87 cm - with stand
2.84 kg
Environmental Standards
ENERGY STAR Qualified
C-Tick, BSMI, NEMKO, SASO, CB, PSB, RoHS, WEEE, GOST-R, REACH, TCO Certified Edge, UkrSEPRO, EuP
Display Type
Diagonal Size
19"
Viewable Size
18.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
HD 1366 x 768
Pixel Pitch
0.3 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour temperature, H-size, aspect control
sRGB colour management, Eco-Mode
2.84 kg
VGA , DVI
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
Backlight Life
30,000 hours
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
17 Watt
Power Consumption Stand by / Sleep
0.3 Watt
10 - 90% (non-condensing)
