BT.com
Wishlist
ViewSonic USB 2.0 WI-FI Dongle
Delivery
Standard Due date unavailable
The ViewSonic PJ-WPD-200 USB wireless adapter provides added convenience and flexibility to your projection needs. With the PJ-WPD-200, you can wirelessly project and you can use your Android or iOS devices to wirelessly stream content to a projector. Equipped with 2T2R MIMO, and support for up to 300Mbps, the PJ-WPD-200 delivers high-speed and robust data transmission via the IEEE 802.11b/g/n protocol. In addition, the portable and compact design of the PJ-WPD-200 provides an easy way for users to wirelessly connect their projectors. The PJ-WPD-200 is compatible with USB 2.0, most laptops, and select ViewSonic projectors equipped with ViewSync Advanced Connect Technology (ACT), as well as select ViewSonic PLED models.
ViewSonic PJ-WPD-200 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
1.6 cm x 2.9 cm x 0.7 cm
3.7 g
802.11b, 802.11g, 802.11n
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Apple MacOS, Microsoft Windows XP / 7 / 8
Network adapter
External
USB 2.0
Wireless
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz
Max Range Open Space
277 m
Ad-Hoc Mode, 2T2R MIMO technology, ViewSync Advanced Connect Technology (ACT)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
1.6 cm
2.9 cm
0.7 cm
3.7 g
Scroll to top
