BT.com
Wishlist
ViewSonic Ultra Short Wall Mount Kit for PJD8653ws/PJD8633ws/PJD8353s
Delivery
Standard Due date unavailable
The ViewSonic PJ-WMK-401 wall mount kit is specifically designed for ultra short throw projectors. This customizable wall mount delivers increased installation flexibility, allowing you to easily mount an ultra short throw projector in nearly any room.
ViewSonic - mounting kit
Mounting kit - wall-mountable
28.3 cm 21.5 cm
Adjustable Depth
52-95.5 cm
Tilt
3.61 kg
Recommended Use
Projector
Max Load Weight
12 kg
Material
Plastic, steel, aluminium alloy
Silver black
ViewSonic PJD8333s, PJD8353S, PJD8633ws, PJD8653WS
28.3 cm
21.5 cm
Adjustable Depth
52-95.5 cm
3.61 kg
Material
Silver black
AV Furniture
Mounting kit
Recommended Use
Projector
Placing / Mounting
Wall-mountable
Tilt
Max Load Weight
12 kg
Swivel adjustment, lateral shift
Scroll to top
