BT.com
Wishlist
ViewSonic TD2420 24" 1920x1080 5ms VGA DVI-D HDMI Multi-Touch LED Monitor
Delivery
Standard Due date unavailable
The ViewSonic TD2420 is the perfect solution for both commercial and consumer touch screen applications. With an intuitive multi-touch LED display, interactive stylus, and full HD resolution, the TD2420 delivers a versatile touch solution for use as a POS display, information kiosk, or in hospital and classroom environments. With Dual Point Optical technology, the TD2420 provides a fun and interactive experience to engage users. Equipped with 1920 x 1080 Full HD resolution, and 20,000,000:1 MEGA Dynamic Contrast Ratio, the ViewSonic TD2420 delivers extremely sharp and crisp images. As a complete multimedia package, the display also includes a pair of integrated 2-watt speakers with SRS Premium Sound. HDMI, VGA, and DVI inputs provide flexible and convenient connectivity, while a VESA-mountable design offers additional convenience for use as a wall-mounted display. The versatile TD2420 is the one-stop solution for your multi-touch display needs.
ViewSonic TD2420 - LED monitor - 24"
LED-backlit LCD monitor - 24" - touchscreen
Energy Class
Class B
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
23 W
Touch-screen
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
210 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
55.59 cm x 17.48 cm x 42.19 cm
3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, SASO, CB, CCC, PSB, RoHS, WEEE, GOST-R, E-Standby, UkrSEPRO, TCO Displays 5.2, KC, ERP
3 years warranty (Austria, Germany, Switzerland - 3 years)
Display Type
Energy Class
Class B
33 kWh
23 W
Diagonal Size
24"
Viewable Size
23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
210 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
7H Hard Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
OptiSync, HDCP, Eco-Mode, SRS Premium Sound, Mega Dynamic Contrast Ratio
55.59 cm x 17.48 cm x 42.19 cm - with stand
3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Optical
VGA , DVI-D (HDCP) , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Stand, stylus
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
Backlight Life
30,000 hours
Supported Windows 7 Features
Windows Touch
Power Supply
Internal
25 Watt
Included Software
ViewSonic Wizard
Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 55.59 cm - depth: 17.48 cm - height: 42.19 cm - weight: 3 kg , Without stand - width: 55.59 cm - depth: 5.61 cm - height: 34.68 cm - weight: 2.4 kg
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
20 - 90% (non-condensing)
Scroll to top
