BT.com
Wishlist
ViewSonic SWB7051 70" Multi-touch Interactive Display
ViewSonic SWB7051 70" Multi-touch...
£8,371.98
£8,371.98
Add to wishlist
Delivery
Standard Due date unavailable
The ViewSonic 69.5" SWB7051 is the ideal interactive display solution for in-classroom teaching, online training sessions, video conferencing and more. This 6-point touch-enabled Smart White board allows two or more users to simultaneously write and draw directly on the display using their fingers or styli. A Full HD LED screen guarantees crisp and vivid image quality with 400-nit brightness, the SWB7051 provides better visual performance in well-lit rooms. Visually attractive, the SWB7051 has an ergonomic design with a tempered glass overlay, anti-glare treatment and rounded corners.
ViewSonic SWB7051 69.5" LED display
LED-backlit LCD flat panel display with built-in PC and touchscreen
Diagonal Class
69.5"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080p, 480i, 576i, 720i
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
2 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Storage Drive Capacity
500 GB
USB
4 ports
Remote Control
Standard remote
Voltage
164.9 cm x 9.7 cm x 99.9 cm
75 kg
Diagonal Class
69.5"
Combined with
Built-in PC and touchscreen
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Whiteboard mode
Timer Functions
Sleep
Design
Rounded-corner design
Protection
Anti-scratch display
164.9 cm
9.7 cm
99.9 cm
75 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
4000:1
Brightness
400 cd/m²
Viewing Angle
88 degrees
Viewing Angle (Vertical)
88 degrees
Touchpoints Qty
6
Response Time
6 ms
Backlight Life
50,000 hour(s)
Key lock
Stands & Mounts
Flat Panel Mount Interface
600 x 600 mm
Video Features
Input Video Formats
Media Player
USB Port
USB Ports Qty
4
PC Configuration
Intel Core i5 / 4 GB
500 GB
Operating System
Windows 8
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance, bass, treble
Speaker System
2 speakers
Output Power / Total
30 Watt
Speakers
2 x main channel speaker - built-in - 15 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Gigabit Ethernet
Connector Type
2 x HDMI , 2 x VGA input , 2 x audio input , S-Video input , Composite video input , Composite video output , Audio input , Component video input , USB , SPDIF input , Serial input , Audio line-out , Microphone , VGA output , Network , 4 x USB 2.0 , USB
3 Touch styluses
VGA cable , USB cable , Audio cable
CCC
Power supply
Nominal Voltage
Width (Shipping)
178.5 cm
Depth (Shipping)
27.5 cm
Height (Shipping)
114 cm
Weight (Shipping)
85 kg
20 - 80% (non-condensing)
Scroll to top
