BT.com
Wishlist
ViewSonic SD-Z225 21.5" 1920x1080 Teradici Tera 2321 512MB VGA DVI USB Zero Client Monitor
ViewSonic SD-Z225 21.5" 1920x1080...
£391.80
Hurry, only 3 left in stock!
£391.80
Add to wishlist
Delivery
Standard 1-3 working days
The ViewSonic SD-Z225 22" (21.5" viewable) zero client monitor is based on Teradici Tera 2321, with hardware accelerated PCoIP support. The SD-Z225 zero client is the perfect solution for companies seeking a seamless desktop experience, with ultra-high security and reliability in networks based on VMware technology. The SD-Z225 is a true zero client and features no local memory or moving parts for the ultimate in energy savings and reliability. The VMware-certified design guarantees performance and compatibility in your network. With the additional DVI output, flexible support is provided for dual-monitor productivity. The eco-friendly design with LED display uses up to 80% less energy consumption than standard PCs.
ViewSonic SD-Z225 - Tera2321 - 512 MB - 0 GB - LED 22"
Thin client - all-in-one
Europe
1 x Teradici Tera2321
RAM
512 MB DDR3 SDRAM
Flash Memory
0 GB
Hard Drive
No HDD
Monitor
22" - LED - 1920 x 1080 (Full HD)
Audio Output
Stereo - integrated
GigE
OS Provided
No operating system
51.64 cm x 18.99 cm x 39.27 cm
5.1 kg
Thin client
Product Form Factor
All-in-one
Built-in Devices
Display
Europe
Processor / Chipset
CPU
Teradici Tera2321
CPU Qty
1
RAM
Installed Size
512 MB
DDR3 SDRAM
Effective Memory Speed
1066 MHz
Flash Memory
Flash Memory
0 GB
Hard Drive
No HDD
Monitor
Monitor Type
LED
Diagonal Size
22"
Native Resolution
Widescreen Display
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Response Time
5 ms
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, Zero Client, Hard Coating (3H)
Graphics Controller
Video Interfaces
VGA, DVI
Audio Output
Integrated
Sound Output Mode
Stereo
Speakers Included
2 x right / left channel
1 x LAN (Gigabit Ethernet) , 1 x DVI-I output , 4 x USB 2.0 , 1 x VGA input , 1 x audio line-in - mini-jack , 1 x headphones - mini-jack , 1 x microphone - mini-jack
VGA cable
Tilt adjustment, white LED lamp, PC over IP (PCoIP) technology, VMware Ready
Theft/Intrusion Protection
Mounting Interface
100 x 100 mm
Power adapter
Nominal Voltage
28 Watt
Operating System / Software
OS Provided
No operating system
Software
ViewSonic Wizard, VMware PCoIP
51.64 cm
18.99 cm
39.27 cm
5.1 kg
35 °C
15 - 90% (non-condensing)
Other bundles
ViewSonic SD-Z225 21.5" 1920x1080 Teradici Tera 2321...
£391.80
Save on TP Link Smart Plug
Save £2.00
£415.77
Scroll to top
