BT.com
Wishlist
ViewSonic PRO8520HD DLP 5000 Lumens Projector
Delivery
Standard Due date unavailable
ViewSonic's industry leading projector, the Pro8520HD, is a Full HD 1080p model that delivers superior and stunning HD image quality onto 30~300" screen. With 5,000 lumens, the Pro8520HD ensures every pixel will stay crystal clear on the large venue even with the wide range of brightness settings. The Pro8520HD supports a Crestron RoomView network management system that efficiently controls and manages all the projectors in the system from a central terminal. Through a RJ45 connection, the Pro8520HD can simultaneously display inputs from 4 different computer screens, provided all devices are connected to the same intranet. This facilitates the development of synergy among the participants. For a PC less presentation, it can also be operated by just plugging in an USB flash to enjoy the content immediately. With 1.5x optical zoom, it enlarges the screen image and fit in anywhere. The versatile interfaces, such as HDMI, RGB, S-video, component inputs and integrated speakers and microphone, allow the Pro8520HD to be used as an audiovisual stereo, making it the optimal solution for projection in large lecture rooms, conference rooms, and public demo rooms.
ViewSonic Pro8520HD DLP projector
DLP projector - High Definition 1080p
Microdisplay
DMD Chip
Brightness
5000 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
1920 x 1080
Native Aspect Ratio
16:9
Bulb type
350 Watt
Bulb life cycle
Up to 2500 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
33.3 cm x 26.3 cm x 12.2 cm
3.86 kg
DLP projector - HD 1080p
Ethernet
Projector
Microdisplay
DMD Chip
Brightness
5000 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
76 cm - 760 cm
Projection Distance
0.9 m - 9.4 m
Throw Ratio
1.4 - 2.14:1
Resolution
1920 x 1080
Native Aspect Ratio
16:9
Max Sync Rate (V x H)
85 Hz x 91 kHz
Bulb type
350 Watt
Bulb life cycle
OSD Languages
Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
6-segment colour wheel, BrilliantColor, USB host function, Crestron RoomView
Lens
Zoom Factor
1.5x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Internal
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x microphone - mini-phone 3.5 mm , 1 x network - RJ-45 , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A , 1 x USB - mini-USB Type B
Carrying case, lens cover, wireless remote control
1 x VGA cable - 1.8 m , 1 x HDMI cable
Security Features
Nominal Voltage
Software Included
ViewSonic Wizard
33.3 cm
26.3 cm
12.2 cm
3.86 kg
10 - 90% (non-condensing)
Scroll to top
