BT.com
Wishlist
ViewSonic PJD8333S DLP XGA 3000 Lumens Projector
Delivery
Standard Due date unavailable
The ViewSonic PJD8333s is an advanced networkable XGA DLP ultra short throw projector that offers advanced connectivity for classrooms and meeting rooms. With an ultra-short throw lens, the PJD8333s can project image from only 2.2 feet away. Equipped with Crestron LAN controller, the PJD8333s makes it easy for IT admin to remotely control and manage multiple projectors from their workstations. Built with BrilliantColor technology, this projector produces vibrant colors. Certified with AMX Device Discovery, the PJD8333s easily integrates into any size campus or enterprise. In addition, the PJD8333s is packed with advanced features including wired and wireless LAN display, LAN control, USB display, a mobile app for smart phones and tablets, capability for PC-less presentations, HDMI that is 3D Blu-ray ready, DynamicEco, and integrated speaker. The PJD8333s is the perfect projector for small spaces and corporate environments.
ViewSonic PJD8333s - DLP projector - 3D
DLP projector
3D Capable
Built-in Devices
Stereo speakers
Brightness
3000 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Lens
Ultra short-throw fixed lens
Bulb type
240 Watt
Bulb life cycle
Up to 3500 hour(s) / up to 7000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
350 Watt
33.5 cm x 26.5 cm x 12.83 cm
3.6 kg
3 years warranty
DLP projector
3D Capable
Built-in Devices
Stereo speakers
Projector
Brightness
3000 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
150 cm - 630 cm
Projection Distance
0.5 m - 2 m
Throw Ratio
0.468:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
240 Watt
Bulb life cycle
Controls & Adjustments
Input select, keystone correction
6-segment colour wheel, BrilliantColor, DLP 3D Ready, Crestron RoomView, AMX Device Discovery, IR Sensor, DynamicEco Mode
Lens
Focus Type
Manual
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video, USB
Video Modes
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x audio line-in / microphone input - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x HDMI - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x USB - mini-USB Type B
Wireless remote control
1 x VGA cable
Plug and Play, FCC Class B certified, UL, C-Tick, ISO 9001, cUL, NOM, SASO, ISO 14001, CB, CCC, PSB, RoHS, WEEE, UL-AR, GOST-R, REACH, UkrSEPRO, KC, TUV Nord, ERP
Nominal Voltage
350 Watt
Power Consumption Operational (Standby)
0.5 Watt
Software Included
ViewSonic Wizard
33.5 cm
26.5 cm
12.83 cm
3.6 kg
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year , Limited warranty - express exchange - 1 year
10 - 90% (non-condensing)
Sound Emission
34 dB
32 dB
Scroll to top
