BT.com
Wishlist
ViewSonic PJD7223 DLP XGA 4000 Lumens Projector
Delivery
Standard Due date unavailable
ViewSonic's PJD7223 is a 4000 lumens and 15,000:1 projector for medium-sized rooms that delivers clear, bright and sharp images with vivid and accurate colors, even in bright environments. This projector features DynamicEco technology to adjust lamp brightness, thereby prolonging the lamp lifespan, lowering power consumption and reducing the total cost of ownership. By pressing the "D.Eco" button on the remote control, the presenter can dim the screen to refocus the audience's attention to the presenter. Equipped with versatile I/O ports, the PJD7223 provides a flexible connectivity to a wide range of devices. The PJD7223 is integrated with a variety of functions and tools, making it a cost-effective option that efficiently and impressively upgrades your presentations.
ViewSonic PJD7223 DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DMD Chip
Brightness
4000 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb life cycle
Up to 3000 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
350 Watt
29.4 cm x 21.9 cm x 11.3 cm
2.14 kg
3 years warranty
DLP projector
3D Capable
Enclosure Colour
Projector
Microdisplay
DMD Chip
Brightness
4000 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
1.2 m - 10 m
Throw Ratio
1.97 - 2.17:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb life cycle
5-segment colour wheel, BrilliantColor, DLP 3D Ready, Auto Vertical Keystone, DynamicEco Mode
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x audio line-in - mini-phone 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) (management) , 1 x USB - 4 pin USB Type B , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA
Remote control
FCC Class B certified, UL, cUL, NOM, SASO, CB, CCC, GOST-R, UkrSEPRO, KC, CECP
Nominal Voltage
350 Watt
29.4 cm
21.9 cm
11.3 cm
2.14 kg
Limited warranty - 3 years
10 - 80% (non-condensing)
Scroll to top
