BT.com
Wishlist
ViewSonic PJD6552LWS WXGA 1280x800 3200 Lumens Projector
ViewSonic PJD6552LWS WXGA 1280x800...
£639.13
£639.13
Add to wishlist
Delivery
Standard Due date unavailable
The ViewSonic LightStream PJD6552LWS networkable projector features 3200 lumens, native WXGA 1280x800 resolution, and an intuitive, user-friendly design. Exclusive SuperColor technology offers a wider color range for true-to-life image projection in any light, while SonicExpert, ViewSonic's proprietary sound enhancement technology, powers a 10W speaker to deliver incredibly clear and audible sound. PortAll - a hidden compartment with an integrated and secure MHL/HDMI port - lets you discretely stream multimedia content from a wireless dongle, or lets you connect to other devices via an HDMI cable. A cable management hood eliminates unsightly cable clutter, and a top lamp door enables easy access for lamp maintenance. A short throw lens with a 0.49 throw ratio offers large projection images for smaller rooms. With HV keystone, corner adjustment, and easy network management, the PJD6552LWS provides flexible setup. Designed with smarter features and extensive connectivity, the networkable short throw PJD6552LWS is ideal for use in education and corporate environments.
ViewSonic LightStream PJD6552LWS DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
White
Built-in Devices
Speaker
United States
Brightness
3200 lumens
Contrast Ratio
22000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb type
210 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM D/K, SECAM B/G, M-NTSC, SECAM L1), LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
330 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.2 kg
3 years warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Ethernet
Enclosure Colour
White
United States
Projector
Brightness
3200 lumens
Contrast Ratio
22000:1 (dynamic)
Image Size
127 cm - 635 cm
Projection Distance
0.53 m - 2.64 m
Throw Ratio
0.49:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
210 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Super Color
Lens
Focus Type
Manual
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
HDMI, composite video, S-Video, RGB, MHL
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
Wireless remote control
1 x VGA cable
Security Features
UL, TUV GS, C-Tick, cUL, ICES-003, SASO, TUV S, CB, CCC, EMC, DOC, PSB, FCC, RoHS, KCC, WEEE, REACH, UkrSEPRO, KC, ERP, EAC, SVHC, CoC
Power Source
AC
Nominal Voltage
330 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
31.6 cm
22.8 cm
10.37 cm
2.2 kg
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year , Limited warranty - express exchange - 1 year
10 - 90% (non-condensing)
Scroll to top
