BT.com
Wishlist
ViewSonic PJD6350 LightStream XGA 3200 Lumens Networkable Projector
Delivery
Standard Due date unavailable
The ViewSonic networkable LightStream PJD6350 features 2x HDMI, 3,200 lumens, high resolution 4:3 (XGA 1024x768), majestic style and thoughtfully intuitive design. It also features a throw ratio of 1.51-1.97 which is ideal for replacing 3LCD projectors like EPSON, NEC, Hitachi, Panasonic, Sony etc.
Exclusive SuperColor 6-Segment Color Wheel maximises colour saturation and brightness for true-to-life image projection in any light, while exclusive SonicExpert speaker design powering a 10W speaker to deliver incredibly clear and audible sound.
A neatly enclosed HDMI-MHL (Media High-Definition Link) compartment supports wireless media streaming from HDMI dongles or MHL connectors (like ViewSonic's WPG-300 and Google Chromecast), while a cable management hood connects onto the back of the projector to eliminate unsightly cable clutter.
With horizontal and vertical keystone correction, corner adjustment, 1.3x optical zoom, and easy network management, the PJD6350 provides flexible setup.
ViewSonic LightStream PJD6350 - DLP projector - portable - 3D - LAN
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
United States
Microdisplay
DMD Chip
Brightness
3200 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM D/K, SECAM B/G, M-NTSC, SECAM L1), LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
315 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.2 kg
3 years warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Ethernet
United States
Projector
Microdisplay
DMD Chip
Brightness
3200 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
1.2 m - 11 m
Throw Ratio
1.51 - 1.97:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Super Color, SonicExpert
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Type
Digital
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
HDMI, composite video, S-Video, RGB
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45
Wireless remote control
1 x VGA cable
Security Features
UL, TUV GS, C-Tick, cUL, ICES-003, SASO, TUV S, CB, CCC, EMC, DOC, PSB, FCC, RoHS, KCC, WEEE, REACH, UkrSEPRO, KC, ERP, EAC, SVHC, CoC
Power Source
AC
Nominal Voltage
315 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
31.6 cm
22.8 cm
10.37 cm
2.2 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year , Limited warranty - express exchange - 1 year
10 - 90% (non-condensing)
Scroll to top
