BT.com
Wishlist
ViewSonic PJD5253 XGA DLP 3300 Lumens Projector
ViewSonic PJD5253 XGA DLP 3300...
£343.27
29 in stock
£343.27
Add to wishlist
Delivery
Standard 1-3 working days
The LightStream PJD5253 makes a big statement with its elegant style and price defying audiovisual performance. Its curvaceous design, which includes a tactile keypad and non-slip foot pads, also presents an intuitive and user-friendly interface. Exclusive SuperColor and SonicExpert technologies provide the optimal visual and audio performance. The PJD5253 boasts a 3,200-lumen lamp with a 15,000:1 contrast ratio, delivering clear and bright images for small to medium meeting rooms or classrooms. Supporting 2x VGA, Composite Video, S-Video, and 1x VGA output, as well as Audio in/out, Mini USB and RS232, this projector has flexible connectivity with analog-based equipment. DynamicEco further reduces power consumption and extends the lamp life significantly.
ViewSonic LightStream PJD5253 DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Europe
Microdisplay
DMD Chip
Contrast Ratio
2400:1 / 15000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
265 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.1 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Europe
Projector
Microdisplay
DMD Chip
Brightness
3200 lumens
Contrast Ratio
Image Size
76.2 cm - 762 cm
Projection Distance
1 m - 8 m
Throw Ratio
1.86 - 2.04:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
ViewMatch, Super Color, DynamicEco Mode, Auto Power Off, auto power on, SonicExpert
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) (management) , 1 x USB - mini-USB Type B
Wireless remote control
1 x VGA cable - 1.8 m
Security Features
UL, TUV GS, C-Tick, cUL, ICES-003, SASO, TUV S, CB, CCC, EMC, DOC, PSB, FCC, RoHS, KCC, WEEE, REACH, UkrSEPRO, KC, ERP, EAC, SVHC, CoC
Power Source
AC
Nominal Voltage
265 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
31.6 cm
22.8 cm
10.37 cm
2.1 kg
10 - 90% (non-condensing)
Sound Emission
34 dB
29 dB
Scroll to top
