BT.com
Wishlist
ViewSonic LightStream PRO7827HD 1920x1080 Full HD 2200 Lumens Projecto
ViewSonic LightStream PRO7827HD...
£784.48
27 in stock
£784.48
Add to wishlist
Delivery
Standard 1-3 working days
Offering incredible color accuracy and stunning, razor-sharp images, the ViewSonic LightStream Pro7827HD is the ideal projector for home entertainment. Featuring Full HD 1080p resolution and ViewSonic's SuperColor RGBRGB technology, this projector delivers incredible detail and brilliantly smooth color gradients for true-to-life image projection. Designed with sRGB/Rec. 709 cinematic colors, ISF certified day and night modes, as well as a unique movie mode, the Pro7827HD delivers optimized color for a true cinema experience. SonicExpert, ViewSonic's proprietary sound enhancement technology, powers a 10W speaker to deliver incredibly clear and audible sound. The Pro7827HD also features a hidden HDMI/MHL connector with 5V USB power, whicokh is perfect for media streaming dongles. With a shorter throw ratio, vertical lens shift, 1.3x optical zoom, smart design, and extensive connectivity, the Pro7827HD provides flexible and quick set-up in any home.
ViewSonic LightStream Pro7827HD DLP projector - 3D
DLP projector - High Definition 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Americas
Brightness
2200 lumens
Contrast Ratio
22000:1
Resolution
1920 x 1080
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens Shift Direction
Vertical
Bulb type
240 Watt
Bulb life cycle
Up to 3500 hour(s) / up to 6500 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM D/K, SECAM B/G, M-NTSC, SECAM L1)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
350 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.6 kg
3 years warranty
DLP projector - HD 1080p
3D Capable
Built-in Devices
Speaker
Americas
Projector
Brightness
2200 lumens
Contrast Ratio
22000:1
Image Size
76 cm - 762 cm
Projection Distance
1.29 m - 14.28 m
Throw Ratio
1.1 - 1.5:1
Resolution
Full HD - 1920 x 1080 (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
240 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, zoom, focus, lens shift dial (vertical)
Super Color, ISF (Imaging Science Foundation)
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-40 / +40
Vertical
Video Input
TV System
Analogue video Signal
Video Interfaces
HDMI, composite video, S-Video, RGB, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A
Cable cover, wireless remote control
1 x VGA cable
Security Features
C-Tick, NOM, TUV S, CB, CCC, FCC, RoHS, WEEE, cTUVus, REACH, ERP, CECP, EAC, SVHC
Power Source
AC
Nominal Voltage
350 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
31.6 cm
22.8 cm
10.37 cm
2.6 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year , Limited warranty - express exchange - 1 year
0 - 90% (non-condensing)
Sound Emission
36 dB
31 dB
Scroll to top
