BT.com
Wishlist
ViewSonic EP5012-TL 50" ePoster 1920x1080 6.5ms VGA HDMI Touchscreen Large Format Display
ViewSonic EP5012-TL 50" ePoster...
£3,043.20
£3,043.20
Add to wishlist
Delivery
Standard Due date unavailable
The ViewSonic EP5012-TL is a 50" all-in-one free-standing ePoster digital kiosk with a sleek, slim design. Great for grabbing attention in busy, high-traffic areas, the EP5012-TL comes with a scratch-proof tempered glass faceplate for added durability. Featuring Full HD 1080p resolution, 176°/176° wide-angle viewing, 50-nit brightness, 5,000:1 contrast ratio, 3 and dual 6W stereo speakers, the EP5012-TL delivers customized multimedia messaging with vivid clarity. Photo and video files can be played back using the integrated media player and 8GB of internal memory, or directly from a USB hard drive. The bundled ePoster Manager Express Plus software makes it easy to load and schedule customized multimedia content. Flexible HDMI, D-sub, USB (x2), and LAN connectivity also allow for additional content loading options from a PC or networkable media player. The EP5012-TL also features an Android platform, enabling the implementation of customized messaging applications. Simple auto on/off scheduling via an on-screen display, as well as a security lock design, make this a reliable, and easy-to-maintain digital signage solution.
ViewSonic EP5012-TL 50" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
50"
Commercial Use
Yes - interactive communication
Country Kits
Europe
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
WLED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
DVR
8 GB
USB
2 ports
Remote Control
Standard remote
Voltage
110 Watt
75.5 cm x 45 cm x 185 cm
87.6 kg
110 Watt
Diagonal Class
50"
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Protection
Tempered glass protection, anti-scratch display
75.5 cm
45 cm
185 cm
87.6 kg
Country Kits
Europe
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
WLED backlight
Coating
Anti-glare, 7H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
5000:1
Brightness
450 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Touchpoints Qty
4
Response Time
6.5 ms
Backlight Life
30,000 hour(s)
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
DVR
DVR
8 GB
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
12 Watt
Speakers
2 x main channel speaker - built-in - 6 Watt
Connector Type
HDMI , VGA input , Audio input , 2 x USB , Network
Hex wrench, key, ePoster Manager Express Plus software
C-Tick, FCC, EAC
Power supply
Nominal Voltage
Power Consumption Stand by
10 Watt
Width (Shipping)
89.75 cm
Depth (Shipping)
57.2 cm
Height (Shipping)
201.8 cm
Weight (Shipping)
98.6 kg
50 °C
20 - 90% (non-condensing)
Scroll to top
