BT.com
Wishlist
ViewSonic CDP4260-TL 42" 1920x1080 HDMI DP DVI LED Large Format Displa
ViewSonic CDP4260-TL 42" 1920x1080...
£2,901.67
£2,901.67
Add to wishlist
Delivery
Standard Due date unavailable
The ViewSonic CDP4260-TL is a 42" commercial LED display designed for use 24 hours a day, 7 days a week. Equipped with 6-point multi-touch functionality, the CDP4260-TL is ideal for providing interactive information in indoor areas such as high-traffic transportation settings, as well as in education, hospitality, and commercial venues. Featuring a slim 19.5mm narrow bezel design, Full HD 1080p resolution, 450-nit high brightness, SuperClear image enhance technology with wide viewing angles, as well as dual 10W stereo speakers, the CDP4260-TL delivers sharp, vivid images with incredible sound for superior multimedia messaging performance. Versatile connectivity options include HDMI, DisplayPort, DVI, D-Sub, YPbPr, and CVBS inputs for easy installation and control of a variety of high-definition devices. A built in OPS slot provides easy connectivity to an integrated PC as well. The CDP4260-TL also supports up to a 5x5 daisy chain installation. In addition, integrated RS232 input and output, with IR pass-through and a content scheduling function, make the CDP4260-TL an easy to-manage solution for 24/7 use.
ViewSonic CDP4260-TL 42" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
250 Watt
97.62 cm x 7.98 cm x 56.95 cm
24.8 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
250 Watt
Diagonal Class
42"
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Design
Narrow Bezel Concept
Dimensions
Without stand
97.62 cm
7.98 cm
56.95 cm
24.8 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Image Contrast Ratio
1300:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
6
Response Time
12 ms
Backlight Life
50,000 hour(s)
Colour Temperature Control
Certified for 24/7 Continuous Operation, 5x5 Daisy-Chain support
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm, 400 x 200 mm
Video Features
Input Video Formats
Remote Control
Standard remote
Audio System
Audio Controls
Balance, bass, treble
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
Network , Serial input , Serial output , HDMI input , DisplayPort input , DVI-D input , DVI-D output , VGA input , Audio line-in , Component video input , Audio line-in , Audio line-out , USB , Speakers output
VGA cable , Serial cable
UL, ISO 9001, cUL, ISO 14001, FCC, WEEE, TUV Nord
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
Width (Shipping)
115.5 cm
Depth (Shipping)
24.2 cm
Height (Shipping)
76.8 cm
Weight (Shipping)
30.6 kg
20 - 80% (non-condensing)
Scroll to top
