BT.com
Wishlist
ViewSonic CDE8452T 84" 3840x2160 HDMI USB Touch Display
ViewSonic CDE8452T 84" 3840x2160...
£6,502.41
Hurry, only 1 left in stock!
£6,502.41
Add to wishlist
Delivery
Standard 1-3 working days
The ViewSonic CDE8452T is a stunning 84" 4K Ultra HD interactive touch display. It is ideal for higher education and corporate meeting applications, as well as for scientific, GIS, and wayfinding applications. The touch-enabled display allows up to ten users to simultaneously write or draw on the display's surface using their fingers or styluses. The large-format LED screen and Ultra HD resolution ensures the perfection in color, clarity, and image detail. Equipped with a tempered glass overlay, anti-glare treatment, and rounded corners, the CDE8452T is designed for heavy usage in high-traffic areas. The ViewSonic CDE8452T Ultra HD interactive touch display is the perfect solution where great imaging and touch interactive performance are needed.
ViewSonic CDE8452T 84" LED display
LED-backlit LCD flat panel display with touch-screen
Diagonal Class
84"
Commercial Use
Yes - interactive communication
Country Kits
United Kingdom, Europe
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
4 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
4 ports
Remote Control
Standard remote
Voltage
500 Watt
197.8 cm x 9.5 cm x 118.7 cm
107 kg
500 Watt
Diagonal Class
84"
Commercial Use
Combined with
Touch-screen
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
4 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Protection
Anti-scratch display
197.8 cm
9.5 cm
118.7 cm
107 kg
Country Kits
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
1600:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
8 ms
Backlight Life
50,000 hour(s)
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
600 x 600 mm
Media Player
USB Port
USB Ports Qty
4
Operating System
Android OS 4.2
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
30 Watt
Bass & treble control, auto volume adjustment, balance control
Speakers
2 x main channel speaker - built-in - 15 Watt
Connector Type
3 x USB 2.0 , USB 3.0 , USB , 4 x HDMI input , 3 x VGA input , 3 x audio line-in , Composite video input , VGA output , Serial
3 styluses, ViewSonic Wizard software CD
VGA cable , USB cable , Audio cable
CCC, FCC
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
217 cm
Depth (Shipping)
32 cm
Height (Shipping)
137 cm
Weight (Shipping)
135 kg
20 - 80% (non-condensing)
Scroll to top
