BT.com
Wishlist
ViewSonic CDE6560T 65" 1920x1080 8ms VGA DVI HDMI DP LED LFD
ViewSonic CDE6560T 65" 1920x1080...
£2,645.91
£2,645.91
Add to wishlist
Delivery
Standard Due date unavailable
ViewSonic CDE6560T 65" Full HD interactive LED display solution is perfect for business and education. This 10-point touch-enabled display, paired with pre-installed annotation software, allows multiple users to simultaneously write or draw on the display's hardness surface using fingers or stylus. A Full HD screen guarantees crisp and vivid image quality, while 360-nit brightness and wide viewing angles provide better visual performance in well-lit rooms. With built-in dual core processor and 8GB internal storage, as well as integrated versatile connectivity including HDMI, VGA, YPbPr, RS232, RJ45 and USB ports, this display provides powerful computing for annotation and multimedia playback without the need for a PC. The CDE6560T is VESA mountable (wall mount kit WMK-047 included for Europe region) or choose the optional trolley cart for flexible installation for classrooms and corporate meeting rooms.
ViewSonic CDE6560T 65" Class (64.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
Yes - interactive communication
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080p, 480i
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Picture Enhancements
Blue Light Filter
Speaker System
2 speakers
USB
4 ports
Remote Control
Standard remote
Voltage
AC 100/240 V (50/60 Hz)
270 Watt
154.5 cm x 9.6 cm x 93.7 cm
69 kg
270 Watt
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Blue Light Filter
Protection
Anti-scratch display
154.5 cm
9.6 cm
93.7 cm
69 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Coating
Anti-glare, 7H Hard
Colour Depth
10-bit colour
Image Contrast Ratio
4000:1
Brightness
360 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
8 ms
Backlight Life
50,000 hour(s)
Colour Temperature Control
Eye Care, infrared multitouch technology, Flicker free technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Video Features
Input Video Formats
Media Player
USB Port
USB Ports Qty
4
PC Configuration
ARM Cortex-A9 Dual-Core / 1.5 GB DDR3 / 8 GB Flash / Mali 400
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Gigabit Ethernet
Connector Type
3 x USB 2.0 , USB 3.0 , USB , 3 x HDMI input , 3 x VGA input , 3 x audio line-in , Composite video input , Digital audio output (optical) , Network , VGA output , Serial input , Headphones
3 styluses, ViewSonic WMK-047 wall mount kit
VGA cable , USB cable , Audio cable , Serial adapter
EAC, EEI
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
171.5 cm
Depth (Shipping)
28 cm
Height (Shipping)
108.5 cm
Weight (Shipping)
80 kg
20 - 80% (non-condensing)
Scroll to top
