BT.com
Wishlist
ViewSonic CDE5560T 55" 1920x1080 6ms VGA DVI HDMI DP LED LFD
ViewSonic CDE5560T 55" 1920x1080...
£2,107.57
£2,107.57
Add to wishlist
Delivery
Standard Due date unavailable
The ViewSonic CDE5560T 55''(54.6'' viewable) Full HD interactive LED display solution is perfect for business and education. This 10-point touch-enabled display, paired with pre-installed annotation software, allows multiple users to simultaneously write or draw on the display's hardness surface using fingers or stylus. A Full HD screen guarantees crisp and vivid image quality, while 350-nit brightness and wide viewing angles provide better visual performance in well-lit rooms. With built-in dual core processor and 8GB internal storage, as well as integrated versatile connectivity including HDMI, VGA, YPbPr, RS232, RJ45 and USB ports, this display provides powerful computing for annotation and multimedia playback without the need for a PC.
ViewSonic CDE5560T 55" Class (54.6" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
Yes - interactive communication
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Blue Light Filter
Speaker System
2 speakers
USB
4 ports
Remote Control
Standard remote
Voltage
190 Watt
131.5 cm x 9.3 cm x 80.5 cm
54 kg
190 Watt
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Blue Light Filter
Protection
Anti-scratch display
131.5 cm
9.3 cm
80.5 cm
54 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 7H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
1400:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
6 ms
Backlight Life
50,000 hour(s)
Infrared multitouch technology, Flicker free technology
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
4
PC Configuration
ARM Cortex-A9 Dual-Core / 1.5 GB DDR3 / 8 GB Flash / Mali 400
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Gigabit Ethernet
Connector Type
3 x USB 2.0 , USB 3.0 , USB , 3 x HDMI input , 3 x VGA input , 3 x audio line-in , Composite video/audio input , Digital audio output (coaxial) , Network , Headphones
3 styluses, ViewSonic WMK-047 wall mount kit
VGA cable , USB cable , Audio cable , Serial adapter
EAC
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
Width (Shipping)
148 cm
Depth (Shipping)
28 cm
Height (Shipping)
95.5 cm
Weight (Shipping)
65 kg
20 - 80% (non-condensing)
Scroll to top
