BT.com
Wishlist
ViewSonic CDE4600-L 46" 1920x1080 8ms VGA DVI HDMI Commercial Display
Delivery
Standard Due date unavailable
The ViewSonic CDE4600-L is a 46" commercial LED display with a 19.5 mm narrow-bezel design. Featuring Full HD 1080p resolution, 350-nit high brightness, 4000:1 high contrast ratio, SuperClear technology for wide viewing angles, and dual 7 W stereo speakers, the CDE4600-L delivers sharp, vivid images with incredible sound for superior multimedia messaging performance. Versatile connectivity options include HDMI, DVI, D-Sub, YPbPr, and CVBS inputs for easy installation and control of a variety of high-definition devices. Integrated RS232 input and output, with IR pass-through and a one-time setting function, make the CDE4600-L an easy-to-manage solution for multiple display configurations. An integrated media player supports the scheduling and playback of photo, music, and video content directly from a USB drive. Content can also be loaded and distributed to multiple displays via LAN RJ45 connection, or wirelessly from mobile devices. The ViewSonic CDE4600-L is the ideal digital signage solution for attracting customers in shopping malls, retail outlets, restaurants, and other indoor commercial areas.
ViewSonic CDE4600-L 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
104 Watt
106.8 cm x 3.88 cm x 62.25 cm
15.3 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
104 Watt
Diagonal Class
46"
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Design
Narrow Bezel Concept
106.8 cm
3.88 cm
62.25 cm
15.3 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
3H Hard, Super Clear
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Backlight Life
50,000 hour(s)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Remote Control Pass Through
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - built-in - 7 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
DLNA
Connector Type
Network , Serial input , Serial output , HDMI input , USB , DVI-D input , Headphones , Component video input , Audio line-in , Audio line-out , SPDIF output , IR Blaster
VGA cable
UL, C-Tick, cUL, ICES-003, CB, FCC, WEEE
Power supply
Nominal Voltage
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
Width (Shipping)
116.4 cm
Depth (Shipping)
14.8 cm
Height (Shipping)
76.8 cm
Weight (Shipping)
17.2 kg
20 - 80% (non-condensing)
Scroll to top
