BT.com
Wishlist
ViewSonic CDE3203 32" 1920x1080p HDMI DVI VGA LED Large Format Display
ViewSonic CDE3203 32" 1920x1080p...
£349.28
£349.28
Add to wishlist
Delivery
Standard Due date unavailable
The ViewSonic CDE3203 is a great value, high performance 32" Full HD LED commercial display for hotel, restaurant and hospitality environments. In addition to versatile connectivity options, including HDMI, VGA, and SPDIF, the display comes with a simple and convenient USB multimedia playback functionality. With 1920 x 1080 resolution, 350-nit brightness, wide viewing angles and dual 10W stereo speakers, the slim-bezel CDE3203 delivers vivid images and remarkable sound for superior multimedia performance. The HDMI CEC pass-through support provides one-touch-play, with additional features for multiple connected devices such as HD set-top-boxes, media players, and Blu-ray players. An RS232 port with IR pass-through provides automated control for hospitality installation. Creating a more comfortable viewing experience, the display is equipped with Flicker-Free and Blue Light Filter technologies. In addition, free-bundled vController software offers easy maintenance and intuitive interfaces for remote management via a PC server or laptop.
ViewSonic CDE3203 32" Class (31.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Yes - digital signage / hospitality
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), Mobile High-Definition Link (MHL)
LCD Backlight Technology
WLED backlight
Image Aspect Ratio
16:9
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 100/240 V (50/60 Hz)
68 Watt
Power Consumption (On mode)
41 W
72.9 cm x 4.85 cm x 42.97 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
68 Watt
41 W
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Video Interface
HDMI Ports Qty
2 ports
PC Interface
Dimensions
Without stand
72.9 cm
4.85 cm
42.97 cm
5.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
WLED backlight
Coating
Anti-glare, hard
Image Contrast Ratio
1200:1
Brightness
320 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Backlight Life
30,000 hours
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
100 x 200 mm
Video Features
Input Video Formats
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Digital Audio Format
Dolby Digital output
Speaker System
2 speakers
Output Power / Total
20 Watt
Balance control
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
MHL/HDMI input - rear , HDMI input - side , DVI-D input - rear , VGA input - side , Audio input - side , USB - side , Serial - side , Remote control output - side , Composite video / component video input - rear , Audio input - rear , SPDIF output - rear , Headphones - rear
2 AAA batteries
CB, FCC, cTUVus, CoC
ENERGY STAR Certified
Power adapter
Nominal Voltage
Dimensions & Weight Details
Panel without stand - 72.9 cm x 4.85 cm x 42.97 cm x 5.3 kg , Panel with stand - 79.6 cm x 16.43 cm x 46.57 cm x 7.4 kg
Width (Shipping)
79.6 cm
Depth (Shipping)
12.1 cm
Height (Shipping)
50.4 cm
Weight (Shipping)
7.2 kg
15 - 90% (non-condensing)
Scroll to top
