BT.com
Wishlist
ViewSonic 43" CDE4302 109.2CM FHD
£482.20
14 in stock
£482.20
Add to wishlist
Delivery
Standard 1-3 working days
The ViewSonic CDE4302 is a 43'' Full HD direct-lit LED commercial display, offering the combination of cost-efficiency and ease of installation for corporate, retail and hospitality environments. With an integrated media player, the CDE4302 is able to easily playback high definition messaging via your USB port. Versatile connectivity options include 2 HDMI ports, VGA, RS232 and SPDIF. The display provides an easy one-time installation and is compatible with many different devices. With Full HD resolution, 350-nit brightness, and wide viewing angles, the slim-bezel CDE4302 delivers sharp and vivid images to ensure smooth content playback. This display also supports HDMI CEC pass-through for one-touch-play and an RS232 control port with IR pass-through for easy installation. The display is also equipped with exclusive eye-care technologies, including Flicker-Free and Blue Light Filter, creating a more comfortable viewing experience. Free-bundled vController software offers easy maintenance and an intuitive interface for remote management via a PC server or laptop.
ViewSonic CDE4302 43" LED display
LED-backlit LCD flat panel display
Diagonal Class
43"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
VA
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Power Consumption (On mode)
105 W
96.82 cm x 5.99 cm x 55.94 cm
8.7 kg
Environmental Standards
ENERGY STAR Qualified
105 W
Diagonal Class
43"
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Timer Functions
Sleep
96.82 cm
5.99 cm
55.94 cm
8.7 kg
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare, 3H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6.5 ms
Backlight Life
30,000 hour(s)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm, 400 x 400 mm
Video Features
Input Video Formats
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Audio Controls
Equalizer, balance
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
VGA input , Serial , 2 x HDMI input , USB 2.0 , Headphones , Audio line-in , SPDIF output , IR Blaster
VGA cable
C-Tick, CB, FCC, WEEE, cTUVus, ERP
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
107 cm
Depth (Shipping)
15.9 cm
Height (Shipping)
69.6 cm
Weight (Shipping)
12.2 kg
20 - 80% (non-condensing)
Scroll to top
