BT.com
Wishlist
Verbatim MediaShare Wireless
£32.74
Hurry, only 1 left in stock!
£32.74
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Portable wireless streaming device for use with your tablet or smart phone. STORE, STREAM & SHARE...Anywhere!
Uses an SD, SDHC, or SDXC card via the SD card slot and/or a USB drive or portable USB hard drive via the USB host port. Both the SD card slot and USB host port are hot swappable, and content can be transferred between the two storage formats when connected.
Access content on any of the above storage formats wirelessly from your iOS or Android tablet/smart phone.
Imagine infinite storage capacity and live video/audio streaming for your tablet or smartphone...too good to be true? Not anymore. Verbatim's new MediaShare Wireless device, allows you to do just that. How does it work? MediaShare allows you to stream media to your tablet/smartphone from portable storage media, such as SD cards, USB drives or portable HDDs (media not included) via a secure, wireless connection, wherever you are! Even better, up to 5 users can access and share stored content - simultaneously!
For maximum mobility, the MediaShare Wireless has a built-in rechargeable battery, with an approximate battery life of up to 9 hours**. To recharge, simply connect the device to any available USB port on your computer. MediaShare Wireless allows you access to your media while charging, so your entertainment or productivity is uninterrupted.
Similar devices are limited by built-in storage capacities, or inability to upload and download information from your tablet/smartphone to your media storage but the Verbatim MediaShare Wireless allows for simultaneous upload, download and streaming! Also, because it utilizes removable media, you'll never run out of space. MediaShare Wireless is the solution for wireless media streaming for anyone on the go.
  • Share - Connect up to 5 devices simultaneously to share videos, music, photos and data
  • Secure - Password protected wireless access to files keeps your data safe and secure
  • USB/SD Connection - Built-in USB port and SD Memory slot allows easy access to content from a USB drive, portable hard drive or SD memory card (Not included)
  • File Manager App - Available iOS and Android mobile app with search utility function to find and navigate data files
  • Extended Battery Life - Up to 9 hours** of continuous battery life for the maximum in mobility
  • Convenient - Upload and Download content wirelessly to and from your tablet or smartphone device
Requirements
  • Requires SD Card or USB Storage Media¹ (Not included)
  • Mobile device internet connection required for app download. iOS app from iTunes Store, or Android app from Google Play Store (free download)
  • Requires: iOS 4.0 or Higher, Android 2.0 or higher.
  • Supported media file types dependent on player installed on mobile device.
  • Supports single or multi device streaming up to a maximum 2Mbps (total)²
¹Note: 1GB capacity or higher recommended. Media must be write-enabled. Up to 200MB of space from the installed storage media is required for system functions and is therefore not available for user data. Storage media format must be NTFS, FAT or FAT32. SDXC card format must be ex-FAT.
²For best playback of content >2Mbps, it is recommended to copy the content to the device.
  • USB Micro B Port: For charging and data transfer. (cable included)
  • USB A Port: For use with USB flash drive/HDD or smartphone/tablet charging.
  • SD Slot: For use with SD cards.
  • IEEE 802.11 b/g/n Compliant*
  • Supports Secure Wireless Encryption using WPA/WPA2-PSK
  • WiFi Security Options: WPA-PSK, WPA2-PSK, Mixed WPA/WPA2-PSK or disabled. (user configurable)
  • 3000mAh Li-ion Battery.
  • Battery Life: Up to 9 hours** continuous use.
  • Charges via USB Micro-B Port.
    • SD/SDHC/SDXC Cards to 64GB.¹
  • USB 2.0/3.0 Flash Drive.
  • USB 2.0/3.0 HDD.
¹Class 4 or higher SD cards recommended.
**Based on <2Mbps single user video playback using 64GB SDXC card or low power USB flash drive. Battery life is subject to many factors including power consumption of removable media as well as state of charge, ambient temperature, number of users, wireless and media operations as well as battery condition. Your results may vary.
Verbatim MediaShare Wireless Streaming Device - network media streaming adapter
Network media streaming adapter
External
802.11b, 802.11g, 802.11n
External
Wireless
Built-in rechargeable Li-ion battery
Processor / Memory
Supported Memory Cards
SDXC Memory Card
Expansion Slots
1
1 x USB 2.0 - 5 pin Micro-USB Type B , 1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
WPA, WPA-PSK, WPA2-PSK
Battery - internal
Scroll to top
