BT.com
Wishlist
Verbatim LED CLASSIC A E27 - Warm White
Delivery
Standard 3-5 working days
Verbatim LED Classic A offers a direct replacement for a conventional incandescent lamp. This dimmable and elegantly designed lamp has a built in temperature control system that protects the lamp electronics from overheating.
  • E27 Socket
  • 220 - 240 V Voltage
  • 30,000 hours lifetime
  • 85% Energy Saving
  • Lumen: 860
  • Equivalent to 63W incandescent bulb
Application - Basic lighting for a comfortable atmosphere at home, in hotel rooms, restaurants and other similar applications.
Verbatim Classic A - LED light bulb
Light Bulb Type
LED light bulb
Bulb Finish
Frosted
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
63 W
Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
3000 K
Luminous Power
860 lumens
Beam Angle
130 degree(s)
Dimmable
No
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Light Bulb
LED light bulb
Bulb Finish
Frosted
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
63 W
A+
Power Factor
0.9
Warm white light
Colour Temperature
3000 K
Colour Rendering Index
80
Luminous Power
860 lumens
Maximum Beam Candela Power
190 cd
Beam Angle
130 degree(s)
Dimmable
No
Lifetime
30000 hours
Switch Cycles
20000
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Package
Blister
Diameter
60 mm
Length
112 mm
199 g
Scroll to top
