BT.com
Wishlist
Veho VSS-002w Mimi 2.4GHz Wireless Speaker System
Delivery
Standard Due date unavailable
Ultra small footprint yet powerful WiFi speaker system. Starter kit includes USB dongle to connect to your notebook/PC or Mimi console system.
The unique new Mimi wireless speaker system allows you to quickly and easily stream music around your home and garden using WiFi technology. Using the supplied plug and play USB transmitting dongle you can transmit music or sounds from your PC or Mac between 30 to 50m (dependant on environment).
You can simultaneously pair an infinite number of speakers with a single dongle so whether you want to stream iTunes, Spotify, internet radio or any other media player, you can listen anywhere in the home or garden at the same time.
As well as being technologically advanced the Mimi wireless also looks stylish and features the Veho tacton rubber touch housing that makes the Mimi speaker look good in any room of the house.
The Mimi also comes with an internal rechargeable battery with up to 8 hours playback time and coupled with the 3.5 mm line in can be used in conjunction with your iPhone/iPod/MP3 player when you are on your travels.
Contents:
- Mimi wireless stereo speaker
- Plug and play USB transmitting dongle
- 3.5 mm line in connector cable
- USB charging cable
- Quick start guide
- User manual
Veho VSS-002W - speaker - for portable use - wireless
Speaker - for portable use
8 cm x 8 cm x 7 cm
Speaker Type
Active
Nominal Output Power (Total)
3 Watt
Audio Amplifier
Integrated
Speaker System Details
2 1.5 Watt
Battery rechargeable - lithium polymer
8 cm
8 cm
7 cm
Enclosure Colour
Speaker System
Speaker Type
Active
3 Watt
Audio Amplifier
Integrated
Transmission Range
50 m
Speakers Included
2 - 1.5 Watt
Connector Type
USB (mini-USB Type A) , Audio line-in (mini-phone stereo 3.5 mm)
Audio cable, USB dongle, USB power cable
Power Source
Run Time (Up To)
8 hour(s)
Scroll to top
