BT.com
Wishlist
Veho V-1 USB Battery Charger
£26.74
18 in stock
£26.74
Add to wishlist
Delivery
Standard 3-5 working days
The V-1 features anti-reverse charging and over-charging protection with a helpful LED display indicator to prevent any damage to the batteries or the USB battery charger and show the charging status.
Charge your batteries anywhere thanks to the included USB-A to micro-USB cable, perfect for charging at home or at work through a USB mains plug or computer. Alternatively, you can charge your V-1 battery charger on the go through your laptop or a portable power banks.
The V-1 Pebble USB battery charger is the must have accessory E-Cigarettes, flashlight and other products that use 18650 or compatible batteries.
Designed in the UK, the Veho V-1 USB battery charger confirms to all safety marks such as CE, EMC and LVD.
The versatile V-1 USB battery charger is compatible with a wide variety of batteries, such as 18650, 10440, 14500, 14650, 16340, 16650, 17650, 17670, 18350, 18490, 18500, 18700, 22650, 20700, 21700, 22700, 25500, 26650 and 26700 batteries.
*Batteries not included
**Not compatible with rechargeable AA or AAA batteries
Veho V1 - battery charger
Battery charger
5 V
Cables
Micro-USB to USB cable
Battery charger
5 V
Max Electric Current
2 A
Reversed polarity protection circuit, LED indicator, short circuit protection, overcharging protection
Supported Battery
Max Supported Qty
4
18650
Lithium Ion
EMC, LVD
Scroll to top
