BT.com
Wishlist
Veho Smartfix Scan to SD Stand Alone Slide and Negative Scanner
Veho Smartfix Scan to SD Stand...
£63.28
£63.28
Add to wishlist
Delivery
Standard Due date unavailable
With 2.4" LCD color screen and built in Lith-ion battery this scanner has true 'stand alone' capability. It also allows you to scan 110 negatives as well as the usual 35mm.
Convert all your old negatives and slides direct to SD Card. No PC or Mac Required, but also PC and Mac compatible. With added convenience of full colour 2.4" LCD screen. Comes with bundled 2GB SD.
Transfer 35mm slides and 35mm & 110mm negatives onto an SD card with the standalone VFS-008 Smartfix scanner.
Veho VFS-008 Smartfix - film scanner (35 mm)
Film scanner (35 mm) - desktop
Interface Type
USB 2.0
Scan Element Type
CMOS
Max Supported Document Size
Film 135 (35mm)
Interpolated Resolution
3600 dpi
Supported Document Type
Slides, film
1 x Lithium Ion
Apple MacOS, Microsoft Windows 7
10 cm x 10 cm x 15 cm
Interface Type
USB 2.0
Film 135 (35mm)
Scanner
3600 dpi
Scan Element Type
CMOS
Scanner Features
Powered by USB port, 2.4" LCD screen
Media Handling
Slides, film
Supported Flash Memory Cards
SD Memory Card
USB 2.0
2 GB SD Memory Card
RoHS
Battery Installed
1 x Lithium Ion
10 cm
10 cm
15 cm
Scroll to top
