BT.com
Wishlist
Veho Portable digital microscope with 1200x digital zoom
Delivery
Standard Due date unavailable
The VMS-005-LCD standalone discovery microscope from Veho has been designed for both home and commercial purposes.
With up to 1200x digital magnification at home this microscope is the perfect educational companion for all the family as well as a great tool for the hobby enthusiast. As a commercial instrument the microscope has a wide range of commercial uses including inspection of electronics, print, hallmarks and of course medical conditions. The LCD screen and rechargeable battery make this the perfect microscope for activities out in the field or on the road. The on board micro SD slot means that images and video can be saved internally on the microscope and downloaded to a PC, Mac or iPad at a later date. Alternatively connect the microscope to a PC or Mac and used the supplied software to calibrate and measure objects.
The timelapse functionality allows timed photographs magnified at up to 1200x to enable timelapse movies such as growing mold or decaying food.
Veho VMS-005-LCD - microscope
Microscope
11.2 cm x 15.5 cm x 23 cm
780 g
Wired
Camera
Optical Zoom
300 x
Frame Rate
30 frames per second
Optical Sensor Type
5 MP
Focus Adjustment
(min distance 1 cm)
USB 2.0, composite video
1 - USB cable - external , 1 - video cable - external
Built-in LED illuminator, 3.5" LCD screen
Microscope
Wired
11.2 cm
15.5 cm
23 cm
780 g
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Camera
Digital Video Format
AVI
Digital Zoom
1200
Image Sensor
5 MP
Lens Construction
Optical Zoom
300 x
Min Focus Distance
1 cm
Video
Composite video
Computer Interface
USB 2.0
Ports
USB 2.0 , Composite video - RCA
Supported Memory Cards
microSD Card, microSDHC Card
Cleaning cloth, 4 GB microSD card, calibration target
1 x USB cable - external , 1 x video cable - external
Lithium Ion 1050 mAh (up to 2 hours)
Microsoft Windows XP SP2, Apple MacOS X 10.6 - 10.8, Microsoft Windows Vista / 7 / 8
System Requirements Details
Pentium II RAM 256 MB
Scroll to top
