BT.com
Wishlist
Veho Pebble Portable Battery Pack Charger - 3000mah
Delivery
Standard Due date unavailable
The powerful PEBBLE Mini Portable Battery charger is the must have accessory to keep all your mobile devices full of charge. It will charge almost any portable device with connectors for Samsung/Blackberry/most mobile phones/USB charged devices/Veho MUVI and KUZO range.
The PEBBLE Mini packs a 3000 Mah which is 2 times the regular battery of the Apple iPhone or smartphone and means it will keep your devices on the go and you won't have to worry about running low on juice.
The PEBBLE Mini is perfect for festivals, camping trips, traveling abroad or as an emergency power pack for those busy days when your devices battery just can't keep up. The PEBBLE Mini will charge almost any portable device with connectors for Samsung/Blackberry/most mobile phones /USB charged devices/Veho MUVI and KUZO range. Simply charge your PEBBLE Mini up via USB and use the various adapters to keep all your mobile devices charged up.
The PEBBLE Mini has a smaller 'credit card' sized footprint perfectly portable and comes with 4 tips, charging cable and funky neoprene pouch to carry it all.
Veho Pebble Mini Portable Battery Charger - external battery pack
External battery pack
6.3 cm x 8.9 cm x 1.4 cm
80 g
3000 mAh
Cables
USB charge cable
6.3 cm
8.9 cm
1.4 cm
80 g
Voltage Provided
5 V
3000 mAh
Overcharge protection, short circuit protection, overdischarge protection
4 connector tips
USB charge cable
Scroll to top
