BT.com
Wishlist
Veho Pebble™ Smartstick+ Emergency Portable Battery - Purple
Charge your portable device on the move
Delivery
Standard Due date unavailable
The Pebble Smartstick+ emergency portable battery pack charger for mobile devices has been enhanced with an increased 2800 mAh power supply, ergonomic re-design with protective port dust cap and handy clip on karabiner.
Charge your portable device on the move without the need for mains power. Small and light enough to carry around in your bag, or clip on your rucksack, the Pebble Smartstick+ portable emergency charger will provide your mobile device with over one additional charge, charging most popular devices including; Apple 30-pin, Blackberry and devices that use mini or micro USB.
The USB port on the Pebble Smartstick also allows you to charge your mobile device with the supplied manufacturer's cable. The stylish design incorporates a screw on cap to protect the Smartstick+ ports and also allow the Pebble karabiner to connect so you can hook onto anything.
Veho Pebble Smartstick+ - external battery pack
External battery pack
11.4 cm
Diameter
2.1 cm
84 g
5 V
Voltage Provided
5 V
2800 mAh
11.4 cm
Diameter
2.1 cm
84 g
Enclosure Colour
Purple
5 V
Voltage Provided
5 V
Max Electric Current
500 mA
LED indicator
Voltage Provided
3.7 V
2800 mAh
USB charging cable, carrying pouch, 3 connector tips, connector cap
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Better Than I Expected!
Reviewed by Mollie on 19/01/2015
I bought this on a whim so really didn't know what to expect.
When it arrived I was pleasantly surprised. The build quality is really nice - not cheap or plasticky. The purple colour is lovely - a rich metallic finish.
The product itself is easy to use. I have an iPhone 5 so I need to use my own cable as it doesn't come with a lighting connector, but that's not a problem. You just unscrew the bit with the nib, plug in the USB, and you're away! There is a keyring type attachment on the "lid" so that you can attach to something to stop it getting lost. My phone charged in a couple of hours whilst I was out. The stick is about the length of a pen but slightly thicker - so it doesn't take up much bag space.
I've used it to charge my little boy's kiddizoom watch as well - which gave me an extra half an hour of peace in the car!
At this price it's a great item to have in the bottom of bag just in case. The build quality and feel of it makes it seem much more expensive.
Scroll to top
