The Pebble™ Aria from Veho combines two of the most popular Veho products in one, portable power and portable audio for your mobile device.
With 3500mAh to charge most smartphones at least twice and a built in 2W speaker to blast out your tunes the Pebble Aria is the perfect travel companion.
The handy 3.5mm interconnecting jack for the speaker acts as the perfect stand for your smartphone so that when it is connected your smartphone is supported with the screen easily accessible.
The Pebble™ Aria with integrated portable power and speaker function is the ideal gadget for travellers, business users, camping, festivals or students.
Key Features:
Box Contains:
