BT.com
Wishlist
Veho MUVI LONG MONOPOD
£25.77
£25.77
Add to wishlist
Delivery
Standard Due date unavailable
The MUVI extra-long extendable monopod from Veho is the perfect monopod for action sports enthusiasts and prosumer filmers. With a super soft rubberized ergonomic grip and adjustable wrist leash it fits perfectly in the hand and will ensure that even if you wipe out you won't lose your camera.
Un-extended the MUVI monopod is 62 cm (24 inches) and using the 2 telescopic extenders with locking joints reaches to a huge 145 cm (57 inches). The MUVI monopod is fitted with a multi directional swivel and locking head and tripod mount which all amounts to self-filming and angles that other smaller monopods are just not capable of.
Veho MUVI Extra-Long Extendable - monopod
Monopod
Tripod Operating Height
62 cm - 145 cm
Muvi Atom, HD, HD10
Monopod
Folded Length
62 cm
Tripod
Tripod Legs Sections Qty
3
Tripod Legs Lock Type
Flip lock lever
Max Operating Height
145 cm
Min Operating Height
62 cm
Supported Devices
Camcorder, camera
Strap, mounting adapter
Veho muvi Atom, HD, HD10
Scroll to top
