BT.com
Wishlist
Veho Muvi K-Series VCC-006-K1 handsfree camera with wi-fi
Veho Muvi K-Series VCC-006-K1...
£222.22
19 in stock
£222.22
Add to wishlist
Delivery
Standard 1-3 working days
The MUVI K2 takes handsfree video capture to the next level. The enhanced MUVI K2 XA-7 Achilles chipset extends your options for filming with a top specification of 1080p @ 60FPS using 19 Mbits/sec. The MUVI K2 also comes ready for watersports including the waterproof case capable of operating at depths of 100 meters (330 feet).
The MUVI K-series has a smaller & sleeker form factor which makes this camera even more versatile than the previous MUVI HD models. Measuring only 6cm x 4cm x 2.3cm (2.7in x 2in x 1in) the K-series is the smallest high definition MUVI yet, meaning handsfree video capture is easier than ever before.
The MUVI K2 records high definition 1080p video at 60 fps as well as 720p at 120fps using the MUVI XA-7 Achilles chipset and has a choice of bit rate default being 19 mbit/s. As well as settings great for handsfree video capture the K2 also has settings to enable broadcast quality video capture for professional and prosumer use.
The K2 captures stills at 8, 12 and 16 mega pixel, and now comes equipped with photo burst mode that allows you to take up to 10 photos per second, which is perfect for trying to achieve the perfect action shot. Additional features include 180° degree rollover which means if you are mounting your K-series upside down the footage plays back the correct way up and G-sensor auto-start which allows you to set your MUVI to start recording on a change of gravity. You can also now capture interval stills during video capture at a set of pre defined periods so you can save the best still images handsfree while capturing footage.
The MUVI K2 now has an interchangeable, rechargeable lithium battery which has a capacity of 1500mAh, the largest on the handsfree camera market, which will allow up to 4 hours of continuous recording.
It also ships with the K-series waterproof case enabling dives of up to 100 m and has operational buttons for video control and photo capture underwater. The K-series waterproof case also has a changeable back door for use with or without LCD backpack and has a port opening for charge and record purposes when your waterproof case is mounted outside water. The K2 is also fully compatible with all the current mount and accessories in the MUVI HD range.
The MUVI K-series now comes with built-in Wi-Fi with a range up to 60 meters, which allows you to connect and pair with your smartphone. The MUVI K-series APP allows you to connect your K-series camcorder wirelessly to your iPhone via Wi-Fi so that you can view live, record videos, take photos and share through email, Facebook, Twitter and more.
The MUVI K2 still has all the features as its predecessor, such as loop-recording, auto video, time lapse continuous photo, exposure control & digital zoom.
Veho muvi K-Series K-2 NPNG - action camera
Action camera - 1080p - widescreen
Action Camera Type
Mountable
Memory Card Slot
microSD card
Sensors
G-sensor
Wireless Interface
Wi-Fi
Sensor Resolution
16.0 MP
Effective Sensor Resolution
Photo: 16.0 MP
Lens System
Wide-angle lens - f/2.7
Focus Adjustment
Focus free
Digital Zoom
10 x
Supported Battery
1 x Li-ion rechargeable battery - 1500 mAh (included)
6 cm x 4 cm x 2.3 cm
Camcorder Sensor Resolution
16.0 MP
Effective Photo Resolution
16.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Digital Zoom
10 x
Sensors
G-sensor
Communications
Wireless Interface
Wireless LAN
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Exposure Modes
Automatic
White Balance
Automatic
Lens System
Focus Adjustment
Focus free
Max View Angle
140 degree(s)
Additional Features
Continuous Shooting Speed
10 frames per second
Additional Features
Date/time stamp, USB charging, Time-Lapse recording, Loop recording, Mirror Upside Down
Action Camera Features
Camera Type
Mountable
Microphone
Microphone Operation Mode
Mono
Connector Type
1 x USB 2.0 , 1 x HDMI output (19 pin micro HDMI Type D)
Carrying case, tripod adapter, lanyard, LCD display, underwater housing, USB charging cable, curved adhesive mount, stickers, helmet front mount, flat adhesive mount, right angle mount, flat touch fastener mount, underwater case tripod mount, anti-fog inserts, underwater housing flat back door, underwater housing back door for LCD, CMOS protector
Underwater Depth
Up to 100m
Details
Battery Life Details
Video recording - 4 hours
Memory / Storage
Memory Card Slot
microSD card
Included Memory Card
8 GB
Memory Card Max Supported Size
32 GB
Video Capture
1920 x 1080 - 60 fps - 19Mbps , 1280 x 720 - 120 fps - 19Mbps
6 cm
4 cm
2.3 cm
Scroll to top
