BT.com
Wishlist
Veho Muvi K-Series VCC-006-K1 handsfree camera with wi-fi
Delivery
Standard Due date unavailable
The MUVI K1 records high definition 1080p video at 30 fps, as well as 720p at 60 fps using the MUVI XA-5 Theseus chipset and has a choice of bit rate default being 16 mbit/s. As well as capturing amazing high definition footage The K1 captures photography stills at 8, 12 or 16 mega pixel, and comes equipped with photo burst mode that allows you to take up to 10 photos per second, which is perfect for trying to achieve the perfect action shot.
Additional features include 180° degree rollover which means if you are mounting your K-Series upside down the footage plays back the correct way up and G-sensor auto-start which allows you to set your MUVI to start recording on a change of gravity.
Veho muvi K-Series K-1 - action camera
Action camera - 1080p - widescreen
Action Camera Type
Mountable
Memory Card Slot
microSD card
Sensors
G-sensor
Wireless Interface
Wi-Fi
Sensor Resolution
16.0 MP
Lens System
Wide-angle lens f/2.7
Focus Adjustment
Focus free
Digital Zoom
10x
Supported Battery
1 x Li-ion rechargeable battery - 1500 mAh (included)
6 cm x 4 cm x 2.3 cm
Camcorder Sensor Resolution
16.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Digital Zoom
10x
Sensors
G-sensor
Wireless LAN
Connectivity Features
Remote control via mobile devices
Exposure & White Balance
Exposure Modes
Automatic
White Balance
Automatic
Lens System
Focus Adjustment
Focus free
Max View Angle
140 degree(s)
Additional Features
Additional Features
Audio recording, auto power save, date/time stamp, interval shooting mode, USB charging, Time-Lapse recording, Auto REC, Loop recording, Mirror Upside Down
Action Camera Features
Camera Type
Mountable
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , HDMI output (19 pin micro HDMI Type D)
Tripod adapter, underwater housing, USB charging cable, flat adhesive mount, right angle mount, flat touch fastener mount
Underwater Depth
Up to 60 m
Details
Battery Life Details
Video recording - 4 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card Max Supported Size
32 GB
Video Capture
1920 x 1080 - 30 fps - 16Mbps , 1280 x 720 - 60 fps - 16Mbps
6 cm
4 cm
2.3 cm
Scroll to top
